Hi, im newbie linuxcnc user, i have cheap chinese paraller port machinehave board one relay pin 17, i build my son first cnc, first time use linux and linuxcnc, my linuxcnc have debian 10 2.8.4-1
problem have i add dual YY motor to step conf wizard, not working, i modified config.ini file
add kinematic XYYZ, joint 4, copy paste Y joint1 to joint2 under Yaxis ,z joint add number 3 have normal.
x,yy, working now normal, but Z not move, and display not come yellow line if move Y axis motor move only, Z axis not move and not draw display yellow line. X move ok and draw line. homing axis show only homing X and Z not show homing all axis. not show Y axis. only X and Z.
unhoming show only unhoming all axis X and Z.
select axis manual display, X home axis ok, yaxis not work, Z axis ok, at display.
why YY not can homing, why Y axis not show. why Z axis not move, why not can homing Y ?
why probe hall meter not show true/false if test. has added to config wizard probe pin 15, and E stop pin 10. but both hall-meter not show contact.
sorry lot have problem because im totally newbie whit linuxcnc and linux user and not undertand code.
sorry not understand good english. finnish understand
