7i96s outputs
- alfredmaina
09 Mar 2023 11:43 #266201
by alfredmaina
7i96s outputs was created by alfredmaina
Hi...can i use output 4 and 5 for torch on and off..the other outputs 00 to 03 seems not to be working..anytime I open linux cnc all outputs from 0 to 4 lights up..can someone kindly assist me on this
- Thank you received: 5308
09 Mar 2023 14:49 #266213
Replied by PCW on topic 7i96s outputs
Output 4,5 are suggested for Plasma applications
If output LEDS 0..3 glow dimly at startup, the 7I96S has been damaged by either
overvoltage on the 5V supply or Outputs 0..3.
