Why is Z0.00 different when using MDI vs running a job?
19 Mar 2023 01:01 - 19 Mar 2023 01:03 #267039 by Sray69
I am having trouble understanding why when I use MDI it is a different distance than when running a job. Here is an example. I set my Touch Off for my Z axis where it was just touching the spoilboard surface. I ran a spoilboard surface job. Later I was adjusting my limit switches to maximize my workspace and wanted to shave off the edges to match the rest of the spoilboard. So I did this in MDI. When I ran G1 Z0.00 the bit cut .001" deeper than when I ran the job at Z0.00. I looked in my INI and I see the MAX_LIMIT is set to 0.001. Is this what is causing this? And why?
Last edit: 19 Mar 2023 01:03 by Sray69.
19 Mar 2023 17:52 #267092 by andypugh
There shouldn't be any difference. Is it possible that you have a tool length offset loaded that was applied in one case and not in the other?
The following user(s) said Thank You: Sray69
19 Mar 2023 19:16 #267097 by JPL
IMHO there could be many explanations why this is happening.
First this is a relatively small error (0.001" = 0.0254mm). I've seen many cheap 'high precision' Chinese 'touch plate' that did not even have have that level of repeatability. I'm assuming here that you touch once for the surface job, then later (after adjusting your limit switches) again for the 'edge' job. Also, touching the tool directly on MDF spoilboard (without touch plate but with feeler gauge) will NEVER result with the precision needed to have a seamless result between the two jobs.
Second, rigidity: The more material you remove the more deflection you will have. Enough difference of forces could certainly account for 0.001" error, unless you have a VERY rigid machine. In any case, finishing a surface in two steps (as you did) is very difficult because you want the tool to be at exactly the same height as it was the first time. This is probably not 0.00 because of the deflection forces and the compression of the material under cut.
20 Mar 2023 04:24 #267114 by Sray69
Not that I am aware of. I did not adjust/change the tool or any tool settings because I did not want to alter the Z0.00 setting. The only thing I did was change the soft limits of the X/Y axes to get the edges.
JPL post=267097 userid=28339
First I do not have my touch plate installed yet so that was not the issue. Second, when I said I touched the tool to the spoilboard that was before I ran the spoilboard job to surface the entire spoilboard. I only wanted it to barely shaved the surface. When that job was done I only made adjustments to the X/Y soft limits so that I could shave off the edge of the spoilboard to match the rest of the board. So no changes to the tool or anything that would affect the Z0.00 setting that the prior job used. Third, because I only shaved the surface (could barely feel the difference) running the job and only took .001 off while running the tool around the edges (via MDI) there was barely any force applied to the Z axis. So I seriously doubt there was enough force applied to make any changes. Sorry if I am not explaining things correctly.
I appreciate both of your suggestions. I had hoped that it was something in my INI. Exactly 0.001" seems oddly coincidental. So just to clarify how it is supposed to work. Wherever I Touch Off the Z axis, that is now Z0.00 whether I run it in a job or manually via MDI, correct?
I guess I will have to do some extensive testing to see how repeatable my Z axis is.
20 Mar 2023 05:09 #267115 by JPL
As  Andypugh mentioned before, that is correct as long as no work or tool offset are active.
This may be a long shot but other factors could be temperature & humidity. MDF will expand under higher humidity, much more than wood (about 5x). This could be the cause of the 0.001" diff. if left long enough (after the first job) in relatively humid condition. This is serious enough for cabinet makers to account for the expansion/contraction caused by a change of relative humidity.
20 Mar 2023 18:04 #267173 by Sray69
The wood expansion is an interesting thought. I didn't trim the edge until the next day. Although the room is kept warm, I am in the PNW during winter so it is moist here.
Well I will be sure to do my testing all at the same time just to be sure.
Time to create page: 0.234 seconds
