error finishing read
20 Mar 2023 15:39 #267157 by CNC_ANDI
error finishing read was created by CNC_ANDI
Hello,
Today i´ve become for the first time the following error.
at the time where i get this error the machine was not working... the programm before was runing fine
20 Mar 2023 15:56 #267161 by PCW
Replied by PCW on topic error finishing read
This indicates a real time issue with network communications
(too many timed out packets)
FIxes
Use as better kernel
Best is 4.19 next best is 6.X 5.X are mostly terrible
Lower the servo thread rate (to say 2000000 ns)
20 Mar 2023 16:25 #267163 by CNC_ANDI
Replied by CNC_ANDI on topic error finishing read
ok so i will test a 4.19 or a 6.x kernel...
thx
20 Mar 2023 17:00 #267168 by PCW
I should also mention that if you have a Intel MAC
you need to disable IRQ coalescing as described
in the hm2_eth manual page.
20 Mar 2023 17:46 #267172 by CNC_ANDI
yes i know. i think i was doing this at the installation.... the system running for few times.
21 Mar 2023 01:03 #267199 by rodw
Replied by rodw on topic error finishing read
Try Debian Bookworm which puts you on the 6.1 kernel
Follow my guide linked here.
forum.linuxcnc.org/9-installing-linuxcnc...g-installation-notes
Its hard to recommend going back to the 4.x kernel as a lot of later hardware is not supported.
21 Mar 2023 18:57 - 21 Mar 2023 19:07 #267245 by CNC_ANDI
hi, i have a second pc already installed with debian bookworm and Porbe_basic....
My machine pc is installed with debian bullseye.... can i install the 6.xx kernel on debian bullseye to?
i will try it. so i have a backup pc :)
Last edit: 21 Mar 2023 19:07 by CNC_ANDI.
21 Mar 2023 23:43 #267264 by rodw
You can try it. If it does not work out you can revert to your previous kernel by selecting a different option in Grub
22 Mar 2023 17:01 #267307 by CNC_ANDI
can´t find a 6.x rt kernel for debian bullseye. i will try the debian bookworm pc later.
22 Mar 2023 19:08 #267311 by rodw
You cold try the image and header files from here
drive.google.com/drive/folders/10uwGg5Rv...k16na?usp=share_link
The following user(s) said Thank You: CNC_ANDI
Time to create page: 0.177 seconds
