error finishing read
- CNC_ANDI
- Thank you received: 31
20 Mar 2023 15:39 #267157
by CNC_ANDI
error finishing read was created by CNC_ANDI
- Thank you received: 5326
20 Mar 2023 15:56 #267161
Replied by PCW on topic error finishing read
This indicates a real time issue with network communications
(too many timed out packets)
FIxes
Use as better kernel
Best is 4.19 next best is 6.X 5.X are mostly terrible
Lower the servo thread rate (to say 2000000 ns)
FIxes
- CNC_ANDI
20 Mar 2023 16:25 #267163
by CNC_ANDI
Replied by CNC_ANDI on topic error finishing read
ok so i will test a 4.19 or a 6.x kernel...
thx
thx
20 Mar 2023 17:00 #267168
I should also mention that if you have a Intel MAC
you need to disable IRQ coalescing as described
in the hm2_eth manual page.
- CNC_ANDI
20 Mar 2023 17:46 #267172
by CNC_ANDI
yes i know. i think i was doing this at the installation.... the system running for few times.
- Thank you received: 4149
21 Mar 2023 01:03 #267199
Replied by rodw on topic error finishing read
Try Debian Bookworm which puts you on the 6.1 kernel
Follow my guide linked here.
forum.linuxcnc.org/9-installing-linuxcnc...g-installation-notes
Its hard to recommend going back to the 4.x kernel as a lot of later hardware is not supported.
- CNC_ANDI
21 Mar 2023 18:57 - 21 Mar 2023 19:07 #267245
by CNC_ANDI
hi, i have a second pc already installed with debian bookworm and Porbe_basic....
My machine pc is installed with debian bullseye.... can i install the 6.xx kernel on debian bullseye to?
i will try it. so i have a backup pc
Last edit: 21 Mar 2023 19:07 by CNC_ANDI.
21 Mar 2023 23:43 #267264
You can try it. If it does not work out you can revert to your previous kernel by selecting a different option in Grub
- CNC_ANDI
22 Mar 2023 17:01 #267307
by CNC_ANDI
can´t find a 6.x rt kernel for debian bullseye. i will try the debian bookworm pc later.
22 Mar 2023 19:08 #267311
drive.google.com/drive/folders/10uwGg5Rv...k16na?usp=share_link
You cold try the image and header files from herecan´t find a 6.x rt kernel for debian bullseye. i will try the debian bookworm pc later.
The following user(s) said Thank You: CNC_ANDI
Time to create page: 0.533 seconds
