Why is Linuxcnc so difficult
22 Mar 2023 19:20 #267312 by Powerhouse.
Why is Linuxcnc so difficult was created by Powerhouse.
Hi I’m new at this I’ve got a Bridgeport series 2 with mach3 on it and want to change to a more stable system
so I bought a mesa 7i96 and raspberry pi there is no way I can get this to work
Next is masso
  • Moderator
  • Moderator
22 Mar 2023 19:57 #267315 by tommylight
Replied by tommylight on topic Why is Linuxcnc so difficult
When you give up on Maso, LinuxCNC will still be here.
22 Mar 2023 20:07 #267317 by PCW
Replied by PCW on topic Why is Linuxcnc so difficult
Choosing a RPI as an initial LinuxCNC host is not the easiest path
What actual issues do you have?
22 Mar 2023 20:11 #267318 by zz912
Replied by zz912 on topic Why is Linuxcnc so difficult
Raspbery is not good for begginer. Better is use Dell Optiplex with normal Debian.
Why is LinuxCNC so difficult?
Because it can do everything.
The ideal situation would be if you could find an LCNC Integrator who would help you and teach you how to use LCNC. Unfortunately, LCNC Integrator is not enough.
22 Mar 2023 22:11 #267324 by Grotius
Replied by Grotius on topic Why is Linuxcnc so difficult
To start with lcnc it is indeed a hard task.
Is your rasperri a ethercat device?
23 Mar 2023 01:21 #267340 by cakeslob
Replied by cakeslob on topic Why is Linuxcnc so difficult
Powerhouse, you are on the right track. Mesa and RPI4 is a good combo, and believe it or not, it is one of the easier things to setup, with the user premade images . Mesa also has great support as well as the included configuration tool, pncconf.
A more productive approach is to ask a specific technical question.
Linuxcnc, and everything linux is so fucking hard all the time, not matter what. But so is everything else I dont understand. Difficulty is negated by reading, learning and sometimes asking for help.
The results are the top tier for its class of cnc controller. There isnt anything better for the price. If you do not need top tier, there are easier things than linuxcnc that can fill your needs. The extra reading required for linuxcnc is worth the time.
Time to create page: 0.142 seconds
