Debian 12
- acourtjester
- Thank you received: 29
29 Mar 2023 18:35 #267839
by acourtjester
Debian 12 was created by acourtjester
Hi
Can linuxcnc be installed on Debian 12 Xfce of other screen sets??
thanks Tom V
thanks Tom V
- Thank you received: 7462
29 Mar 2023 19:06 - 29 Mar 2023 22:46 #267844
Replied by tommylight on topic Debian 12
That should be BookWorm, so yes, RodW made a how to, but the gist of it it
Install Debian BookWorm
Update and upgrade
sudo apt install linuxcnc
That should be all.
Choose the non free version of Debian.
Edit:
As noted by RodW, the non free version of Debian is now the mainstream one.
Update and upgrade
That should be all.
Edit:
Last edit: 29 Mar 2023 22:46 by tommylight. Reason: more info
- acourtjester
29 Mar 2023 19:43 #267849
by acourtjester
Replied by acourtjester on topic Debian 12
thanks for the reply I an following the instructions posted by RodW as I found them after the question I posted. I am just about finished but a little confused at the last few instructions (25 and beyond) very new to Linux
- JPL
- Thank you received: 118
29 Mar 2023 19:56 #267850
by JPL
Replied by JPL on topic Debian 12
25 and beyond (everything after 24 Check latency) are 'optional' steps.
25- Only if you need qtvcp and probe basic
26- Only if you need Ethercat
... etc ...
... etc ...
- acourtjester
29 Mar 2023 20:13 #267852
by acourtjester
great thanks for the reply I'm stopping now it looks like it is finished and will test in the morning
- Thank you received: 4138
29 Mar 2023 20:32 #267856
Replied by rodw on topic Debian 12
As stated above the install really stops at point 20. I updated the how to to mke this clear.
Some would argue that isolcpus is mandatory (steps 21-23)
latency-histogram (point 24) is the preferred method for looking at latency. If you are using a mesa card or ethercat, you don't use a base thread so we use the parameter --nobase
We use xfce because it is an xorg environment and the default gnome uses the newer wayland environment. Linuxcnc has some problems with wayland so its safer to use a xorg environment. I might add Linuxcnc's issues are generally due to issues in other uptream code.
Tommy, note that in Bookworm, there is now no need to select the non-free version as the alpha version I linked to and the final release when it happens include the non-free code as part of the standard installation.
For others wondering about this non-free mumbo jumbo,Prevoiusly Deban did not include any kernel drivers that did not have source code available. A lot of manufacturers only offer precompiled binaries so often the hardware performs poorly or not at all. Finally, Debian has seen the light.
The following user(s) said Thank You: tommylight, Pro_El
29 Mar 2023 22:44 #267872
Noted, thank you.Tommy, note that in Bookworm, there is now no need to select the non-free version as the alpha version I linked to and the final release when it happens include the non-free code as part of the standard installation.
Time to create page: 0.556 seconds
