Servo Speed
- OldSQL
01 Apr 2023 19:08 #268029
by OldSQL
Servo Speed was created by OldSQL
Hello,I am considering using the Mesa 7i96s motion control board to provide step and direction signals to AC servo drives. However, i'm concerned that the 1/25 gear box on my motors and the current servo thrill of 800,000 may limit my speed capabilities.
Do you think I can achieve decent speeds with this setup, or will my speed be significantly restricted?
- Thank you received: 5308
01 Apr 2023 20:08 - 01 Apr 2023 20:09 #268034
Replied by PCW on topic Servo Speed
If you meant "servo- thread" then no, the servo thread rate does no affect the maximum
step rate. With a hardware stepgen, the maximum step rate is usually limited by the drives
minimum step times rather than the interface hardware.
Last edit: 01 Apr 2023 20:09 by PCW.
Time to create page: 0.763 seconds
