Spindle encoder with one intiator but 4 pulses per revolution
- fletch
- Thank you received: 72
02 Apr 2023 19:55 #268103
by fletch
Spindle encoder with one intiator but 4 pulses per revolution was created by fletch
This is a follow on from @Sviper's post: forum.linuxcnc.org/38-general-linuxcnc-q...e-emulate-an-encoder which I was hoping I could use directly. But on dismantling the sensor on my mill it turns out to be a photo interruptor with four 'windows' per revolution. I suspect this is a fairly common implementation on the import mills.
I haven't yet tried to implement the above post as I'm waiting for the hardware to arrive (I'll be running two photo interrupters - one for the mill's 'vfd' display and new one for the 7i96 to consume so I can compare the numbers) but I'm if I'm reading it correctly, I'll be reporting 4x the rpm.
Is there a way to apply a 'divide by 4' in the hal config?
- Thank you received: 7462
02 Apr 2023 21:38 #268118
Replied by tommylight on topic Spindle encoder with one intiator but 4 pulses per revolution
linuxcnc.org/docs/html/man/man9/encoder.9.html
See under PINS
encoder.N.counter-mode
and
encoder.N.x4-mode
See under PINS
and
encoder.N.x4-mode
The following user(s) said Thank You: fletch
- fletch
02 Apr 2023 22:50 - 02 Apr 2023 23:03 #268126
by fletch
Replied by fletch on topic Spindle encoder with one intiator but 4 pulses per revolution
Thank you Tommy - in the Sviper post, Andy Pugh replies saying to set counter-mode to 1 which according to the docs would mean x4-mode will be ignored.
I think perhaps I may have asked the wrong question - all encoders 'pulse' multiple times per revolution, so the question I should be asking is where do I set the encoder resolution for the spindle?
Edit: Now that I've thought about the question, position-scale seems like a suitable candidate?
Last edit: 02 Apr 2023 23:03 by fletch. Reason: Refined my google-foo by asking the wrong question
03 Apr 2023 01:16 #268136
In the hal file, there should be a whole section about spindle feedback, there should be encoder-scaleIn this case the encoder scale is set in the ini file and read from there.
This is from an old retrofit, so use with caution.
setp hm2_7i92.0.encoder.05.counter-mode 0
setp hm2_7i92.0.encoder.05.filter 1
setp hm2_7i92.0.encoder.05.index-invert 0
setp hm2_7i92.0.encoder.05.index-mask 0
setp hm2_7i92.0.encoder.05.index-mask-invert 0
setp hm2_7i92.0.encoder.05.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i92.0.encoder.05.position
net spindle-vel-fb-rps <= hm2_7i92.0.encoder.05.velocity
net spindle-index-enable <=> hm2_7i92.0.encoder.05.index-enableThis is from an old retrofit, so use with caution.
- fletch
03 Apr 2023 08:57 #268155
by fletch
Aha! Thank you. I think I'd searched my .hal file for 'encoder' before actually assigning 'Spindle' to the 'Quad Enc-A/B/I' inputs - Doh!
I will be able to test as soon as the parts arrive (and I summon my inner Binky to make a custom bracket)...
- fletch
20 Apr 2023 16:24 - 20 Apr 2023 16:26 #269491
by fletch
You know I can't leave this alone, don't you? So I've started designing a quadrature encoder+index that I can strap to the spindle inside the mill head (where the current single pulse encoder is):
This is currently designed with 128 'windows' which if I understand quadrature correctly and set the two readers x.5 windows apart I should get 512 position 'indications' per revolution - rigid tapping FTW?
I've tested 3D printing up to 250 windows but I'm not sure the opto switches I've ordered (EE-SX1025, 0.5mm window) will read that resolution reliably..
On the Mesa 7i96 card, I have the option of single ended or differential mode - initially for testing I'll use single ended mode as is currently working for four 'windows' non-quadrature, but was wondering about the value of trying to implement differential mode and what that circuit/electronics would look like? Probably not the right place to ask, but everyone on here seems much smarter than me...
Last edit: 20 Apr 2023 16:26 by fletch. Reason: Randon image resizing strings in the test.
- Thank you received: 5308
20 Apr 2023 17:39 - 20 Apr 2023 17:40 #269496
Replied by PCW on topic Spindle encoder with one intiator but 4 pulses per revolution
To convert single ended to differential, you typically use a
differential driver chip like a 26ls31 or equivalent.
You can use lower resolution opto devices by using a Moire mask
(as most high resolution encoders use)
This mask is just a sector of your disk with the same pitch slots
but 2 sections with the slots in the second section having a 1/4
pitch (1/2 slot width) offset from the first section.
These allow large area light source and sensors.
Last edit: 20 Apr 2023 17:40 by PCW.
- fletch
20 Apr 2023 18:33 #269498
by fletch
Brilliant! Thank you. The
26LS31
is something I shall have to investigate - a bit above my pay grade, but I'm sure I can learn...
I thought this is what you mean by Moire:
with each opto switch reading a different 'track', but now I'm thinking I've got it wrong because I can't see the difference between what I've drawn and just offsetting the two opto switches by half a slot?
I found this industrytoday.com/encoder-performance/ but they are showing an led+mask+photodiodes - the EE-SX1025 I'll be using already has a 0.5mm 'mask'. I suspect much experimentation is needed - I'm only going to 4,000rpm - the only question is, can I get the resolution good enough for rigid tapping...
- fletch
20 Apr 2023 18:43 - 20 Apr 2023 18:44 #269501
by fletch
I think I've got my head around the moire mask now - if I was using a opto receiver & separate light source it would be the right thing but don't think it would make any difference to the
EE-SX1025
's 0.5mm receiving slot.
Last edit: 20 Apr 2023 18:44 by fletch.
Time to create page: 0.129 seconds
