Python - yield INTERP_EXECUTE_FINISH
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Apr 2023 17:53 #269014 by zz912
Replied by zz912 on topic Python - yield INTERP_EXECUTE_FINISH
I tried doing it the other way around. I created an ngc file and wrote python commands in it:
;py,print("Hello")
G1 X10 Y10 f50
;py,print("I moved")
G1 X20 Y20 f50
;py,print("I moved to second place")
M30
Unfortunately, it doesn't work the way I want it to.
It makes:
1) Print "Hello" "I moved" "I moved to second place"
2) move to x20 y20
I would like to ask if there is documentation for the command ";py," for the interpreter. I can't find anything anywhere.
13 Sep 2024 11:59 #310064 by rockcnc
Replied by rockcnc on topic Python - yield INTERP_EXECUTE_FINISH
hey zz912
did you solve this problem?
i have the same problem and stuck in it for a while ):
  • zz912
  • Platinum Member
  • Platinum Member
13 Sep 2024 12:07 #310065 by zz912
I made my remap in G-code.
Python doesnt like me.
13 Sep 2024 12:23 #310066 by rockcnc
can you please give me an example of your G-code
just like you i need to wait for some entrance
  • zz912
  • Platinum Member
  • Platinum Member
13 Sep 2024 12:27 #310067 by zz912
o<atc-right> sub
M66E0L0 (Přepočítání LCNC)
o401 if [#<_hal[hm2_7i96.0.gpio.009.in]> NE 1]
(MSG, Osa Z nesepla horní mikrospínač)
M2
o401 endif
M64 P3 (DO_3 ON - zapnuti otaceni karuselu)
(Čekání na dotočení karuselu)
#1 = 0
M66E0L0
o201 while [#<_hal[carousel.0.active]> NE 0]
G4 P0.1 (Počkej 0.1 sekundy)
M66E0L0
#1 = [#1+1] (increment the test counter)
o202 if [#1 GT 60]
(DEBUG, Karusel se otáčel moc dlouho - #1 sekund)
M65 P3 (DO_3 OFF - vypnuti otaceni karuselu)
M2
o202 endif
o201 endwhile
G4 P0.05 (Počkej 0.05 sekundy)
M66E0L0
M61 Q#<_hal[carousel.0.current-position]>
G43 H#<_hal[carousel.0.current-position]>
G4 P0.01
M66E0L0
f50 (nastaveni minimalni rychlosti)
o<atc-right> endsub [1]
M2
The following user(s) said Thank You: rockcnc
13 Sep 2024 13:15 #310074 by rockcnc
Thankyou
I send "z_up" with stm with serial and in exact moment I need z axis to go up
i really don't understand what you saying
can you help me please?
  • zz912
  • Platinum Member
  • Platinum Member
13 Sep 2024 13:28 #310076 by zz912
I have no problem helping you, BUT you must describe what you exactly need:
- we need wiring diagrams (or description electronic)
- your current LCNC configuration
- description of machine/ATC function
- photos of the machine would help
Start a new thread called, for example, ATC - rockcnc.
13 Sep 2024 13:34 - 13 Sep 2024 13:46 #310077 by Aciera
Last edit: 13 Sep 2024 13:46 by Aciera.
The following user(s) said Thank You: zz912
Time to create page: 0.441 seconds
