- Thank you received: 118
This probably wont change anything but the newer 7i92T are using an Efinix T20F256 FPGA (blame it on chips shortage) image missing /media/kunena/emoticons/whistling.pngThe Mesa 7i92 uses a Xilinx FPGA. I worked for Altera for many years so it is out of the question.
Yes, this could be since Mach3 configs are XML files. Maybe check the date of the file to find out if it was created/edited before you've install linuxcnc?Could the XML file be something left over from when I converted from Mach to LinuxCNC ? It was years ago so I have forgotten.
