- Thank you received: 118
For loadrt [KINS]KINEMATICS you first need to inspect the [KINS] section of your INI file (not HAL). You should find something like:Any ideas on the loadrt [KINS]KINEMATICS issue ? Is the XML file part of the configuration ?
