a busted machine
  • clive
  • clive's Avatar Topic Author
  • Senior Member
  • Senior Member
19 Apr 2023 05:25 #269400 by clive
Replied by clive on topic a busted machine
I've started to bring up an entirely new computer using version 2.8 -- (I have a feeling this is a bad idea)
The installation process stumbles when it comes to partitioning the disk. I was going to use a flash SSD drive but that always failed at the partitioning stage. I have tried the LVM option (I have no idea what LVM stands for, Logical Volume Manager perhaps?) and it goes further and completes the install but has trouble with the update mirror, which it can't find. In my other many Linux installations mirrors are selected at any time, not just at installation. Mirrors come, mirrors go...
Finally, I tried "lspci" and it isn't there. Nor is lsusb or other Linux utilities (haven't looked extensively). Without lspci I can't locate the installed address of the parallel port card.
Maybe without the mirror the installation is incomplete ?
  • clive
  • Senior Member
  • Senior Member
19 Apr 2023 17:05 #269428 by clive
I'm continuing with a new machine and 2.8. I tried the "graphical install" and it seems to be more complete. lspci works. All very odd.
The LinuxCNC/Debian system has a broken networking facility (the network itself is fine). The error message reads: Failed to Open "/ on" This is not good because I use the network extensively when working with the CNC machine. I commonly have two other workstations I use to create my G-Code. Moving files around with a USB drive is no good.
Any advice on getting the network browser to work ?
19 Apr 2023 17:37 #269436 by JPL
Replied by JPL on topic a busted machine
I can't help you much about linux/debian itself as I'm far from being an expert but I think you should open a new discussion for this under 'Installing LinuxCNC' since this is not much related with the title of this topic anymore.
Good luck.
  • clive
  • Senior Member
  • Senior Member
19 Apr 2023 19:40 #269450 by clive
The solution to my networking problem I found here:
superuser.com/questions/1751118/cant-con...erver-debian-11-xfce
It is unfortunate that the 2.8 installer doesn't by default install networking.sudo apt install gvfs-backends
cifs-utils
samba smbclient
At last I have the machine recognizing an add-in parallel port with LinuxCNC installed on an SSD.
  • clive
  • Senior Member
  • Senior Member
21 Apr 2023 01:09 #269533 by clive
I have LinuxCNC seemingly happy with both the ini and the hal I created for the new computer. However, when LinuxCNC starts up it reports:
No parport registered at 0x4000. This is not always an error. Continuing
I have to say I don't like this. lspci -v reports that the StarTech parallel port is at 0x4000 and 0x4010. I happen to be 140 miles from the CNC hardware so I can't readily check if LinuxCNC really is connected to the parallel port. I assume I will get this pseudo-error every time I fire up LinuxCNC even when connected to my CNC hardware.
This is most likely because the parallel port has no register read-back facility so LinuxCNC just sends something to 0x4000 and if Debian doesn't complain it maybe is OK. A better solution would be to have the user temporarily short pins 14 and 15 on the parallel port and do a simple loop-back test.
  • clive
  • Senior Member
  • Senior Member
21 Apr 2023 18:11 - 21 Apr 2023 18:36 #269572 by clive
It seems that the OS needs to be told that the parallel port is present. Executing the following removes the pseudo error message:
sudo modprobe parport_pc io=0x4000
So the installations sequence should read: lspci -v to get the address of the parallel port then let the OS know it is active via modprobe.
This fixes the problem but not permanently. The fix has to be run every time the machine is booted.
Last edit: 21 Apr 2023 18:36 by clive.
21 Apr 2023 20:48 #269580 by rodw
Replied by rodw on topic a busted machine
Copy the old folder to
~/linuxcnc/configs
21 Apr 2023 21:54 #269584 by tommylight
Replied by tommylight on topic a busted machine
The error mentions it is not always an error and it continues, so it does work without modprobe stuff, granted the address is correct.
Did you test it without modprobe?
  • clive
  • Senior Member
  • Senior Member
21 Apr 2023 23:10 #269586 by clive
As I mentioned, I'm 140 miles away from the actual CNC machine. It will be a week before the computer gets hooked up to the hardware. My task is to check things out, as far as possible, beforehand.
I simply don't like things that are pseudo-errors. There are three classes of reports that I use in my code:
  1. Error             He's Dead, Jim. Do not pass GO, do not collect $200.
  2. Warning        Not good, but something needs to be checked or fixed. For production release there should be no warnings.
  3. Information   blah, blah, blah...
The time at the CNC machine is somewhat constrained so I want to be up and running without fuss. I'll probably re-check the the XY&Z scales but that is about all.
We use the machine for art making purposes and my collaborator is only available to visit one week a year. You can see our work here:
  Howe-McCarthy
22 Apr 2023 01:09 #269589 by tommylight
Hmm i have seen that work before, somehow! :) Nice work.
You do not need the machine to check if a parallel port works, you need a piece of short wire:
Pins 10,11,12,13 and 15 are inputs, so use the included "port tester" from the LinuxCNC config chooser, it wiil copy stuff to the config folder and fail, edit the hal file inside the folder it created by deleting the 0x378 address and adding you port address, start the config chooser again and chose that config but this time from the top "my configurations" folder.
watch the LED's on screen while using the above mentioned piece of wire, insert one side in the above mentioned pins and touch the other side to the port metal frame, the LED should change color.
If that works, the port is all good and dandy.
Time to create page: 0.177 seconds
