Using Proma THC with a mesa 7I96S
- lukeisok
15 Apr 2023 16:21 #269121
by lukeisok
Using Proma THC with a mesa 7I96S was created by lukeisok
Hello,
I bought the Proma THC 150 while my CNC plasma was still on Mach3. I am looking to switch to LinuxCNC on a budget. Will my Proma THC work with the mesa board and Linux CNC? I can only find posts about using THCAD-5/10/... (and I know that would be a better solution in the long run, but currently I just want to continue using the Proma as it is wired up, set up and I know it works -> if it ain't broke don't fix it!) with LinuxCNC so I just want to be sure it will all work together.
- Thank you received: 7462
15 Apr 2023 16:26 #269123
Replied by tommylight on topic Using Proma THC with a mesa 7I96S
Yes it does work with all Mesa boards, Proma 150 has relays on outputs so can be wired to pretty much anything.
- lukeisok
15 Apr 2023 16:26 #269124
by lukeisok
Replied by lukeisok on topic Using Proma THC with a mesa 7I96S
Thanks!
Time to create page: 0.754 seconds
