Error message
- gwiz
27 Apr 2023 06:26 #270039
by gwiz
Error message was created by gwiz
Hi everyone,
I am totally new to linux. We bought a computer that has Linuxcnc, with the intention to run a plasma cutter. A while ago, the app was opening totally fine on the computer. Now it comes up with an error message that I have no idea how to interpret. I will paste it below, any help would be great. Thanks in advance
Print file information:RUN_IN_PLACE=noLINUXCNC_DIR=LINUXCNC_BIN_DIR=/usr/binLINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcncLINUXCNC_SCRIPT_DIR=LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcncLINUXCNC_CONFIG_DIR=LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgsINIVAR=inivarHALCMD=halcmdLINUXCNC_EMCSH=/usr/bin/wish8.5LINUXCNC - 2.7.0Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/plasma2'Machine configuration file is 'plasma2.ini'INIFILE=/home/linuxcnc/linuxcnc/configs/plasma2/plasma2.iniPARAMETER_FILE=linuxcnc.varTASK=milltaskHALUI=haluiDISPLAY=axisCleaning up old LinuxCNC...Shutting down and cleaning up LinuxCNC...Waiting for other session to finish exiting... OkStarting LinuxCNC...Starting LinuxCNC server program: linuxcncsvrLoading Real Time OS, RTAPI, and HAL_LIB modulesStarting LinuxCNC IO program: ioStarting HAL User Interface program: haluiFound file(REL): ./plasma2.halShutting down and cleaning up LinuxCNC...Killing task linuxcncsvr, PID=4331Removing HAL_LIB, RTAPI, and Real Time OS modulesRemoving NML shared memory segments Debug file information:.Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_parport.ko: No such device./plasma2.hal:6: exit value: 1./plasma2.hal:6: insmod for hal_parport failed, returned -1See the output of 'dmesg' for more information.4331 PID TTY STAT TIME COMMANDStopping realtime threadsUnloading hal components Kernel message information:[ 0.000000] Initializing cgroup subsys cpuset[ 0.000000] Initializing cgroup subsys cpu[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc[ 0.000000] BIOS-provided physical RAM map:[ 0.000000] BIOS-e820: 0000000000000000 - 0000000000094000 (usable)[ 0.000000] BIOS-e820: 0000000000094000 - 00000000000a0000 (reserved)[ 0.000000] BIOS-e820: 00000000000e5000 - 0000000000100000 (reserved)[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bdd90000 (usable)[ 0.000000] BIOS-e820: 00000000bdd90000 - 00000000bdd9e000 (ACPI data)[ 0.000000] BIOS-e820: 00000000bdd9e000 - 00000000bdde0000 (ACPI NVS)[ 0.000000] BIOS-e820: 00000000bdde0000 - 00000000c0000000 (reserved)[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed01100 (reserved)[ 0.000000] BIOS-e820: 00000000fed02000 - 00000000fed14c00 (reserved)[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000fed40000 (reserved)[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)[ 0.000000] BIOS-e820: 0000000100000000 - 000000013c000000 (usable)[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel![ 0.000000] SMBIOS 2.5 present.[ 0.000000] DMI: Acer Veriton M670G/M670 /EQ45M, BIOS R01-A4 03/20/2009[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)[ 0.000000] last_pfn = 0xbdd90 max_arch_pfn = 0x100000[ 0.000000] MTRR default type: uncachable[ 0.000000] MTRR fixed ranges enabled:[ 0.000000] 00000-9FFFF write-back[ 0.000000] A0000-BFFFF uncachable[ 0.000000] C0000-CFFFF write-protect[ 0.000000] D0000-DFFFF uncachable[ 0.000000] E0000-EFFFF write-through[ 0.000000] F0000-FFFFF write-protect[ 0.000000] MTRR variable ranges enabled:[ 0.000000] 0 base 13C000000 mask FFC000000 uncachable[ 0.000000] 1 base 000000000 mask F00000000 write-back[ 0.000000] 2 base 100000000 mask FC0000000 write-back[ 0.000000] 3 base 0C0000000 mask FC0000000 uncachable[ 0.000000] 4 base 0BDE00000 mask FFFE00000 uncachable[ 0.000000] 5 base 0BE000000 mask FFE000000 uncachable[ 0.000000] 6 disabled[ 0.000000] 7 disabled[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106[ 0.000000] e820 update range: 00000000bde00000 - 0000000100000000 (usable) ==> (reserved)[ 0.000000] found SMP MP-table at [c00ff780] ff780[ 0.000000] initial memory mapped : 0 - 01800000[ 0.000000] Base memory trampoline at [c0090000] 90000 size 16384[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000[ 0.000000] 0000000000 - 0000400000 page 4k[ 0.000000] 0000400000 - 0037400000 page 2M[ 0.000000] 0037400000 - 00377fe000 page 4k[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff][ 0.000000] RAMDISK: 36412000 - 37201000[ 0.000000] ACPI: RSDP 000fa770 00014 (v00 ACPIAM)[ 0.000000] ACPI: RSDT bdd90000 0004C (v01 ACRSYS ACRPRDCT 20090320 MSFT 00000097)[ 0.000000] ACPI: FACP bdd90200 00084 (v01 032009 FACP1033 20090320 MSFT 00000097)[ 0.000000] ACPI: DSDT bdd905c0 06E8B (v01 1AAAA 1AAAA000 00000000 INTL 20051117)[ 0.000000] ACPI: FACS bdd9e000 00040[ 0.000000] ACPI: APIC bdd90390 0006C (v01 032009 APIC1033 20090320 MSFT 00000097)[ 0.000000] ACPI: MCFG bdd90400 0003C (v01 032009 OEMMCFG 20090320 MSFT 00000097)[ 0.000000] ACPI: SLIC bdd90440 00176 (v01 ACRSYS ACRPRDCT 20090320 MSFT 00000097)[ 0.000000] ACPI: OEMB bdd9e040 00072 (v01 032009 OEMB1033 20090320 MSFT 00000097)[ 0.000000] ACPI: HPET bdd985c0 00038 (v01 032009 OEMHPET 20090320 MSFT 00000097)[ 0.000000] ACPI: ASF! bdd98600 00099 (v32 LEGEND I865PASF 00000001 INTL 20051117)[ 0.000000] ACPI: GSCI bdd9e0c0 02024 (v01 032009 GMCHSCI 20090320 MSFT 00000097)[ 0.000000] ACPI: TCPA bdd986a0 00032 (v01 032009 TBLOEMID 00000001 MSFT 00000097)[ 0.000000] ACPI: AWMI bddb1710 0004E (v01 032009 OEMB1033 20090320 MSFT 00000097)[ 0.000000] ACPI: Local APIC address 0xfee00000[ 0.000000] 2149MB HIGHMEM available.[ 0.000000] 887MB LOWMEM available.[ 0.000000] mapped low ram: 0 - 377fe000[ 0.000000] low ram: 0 - 377fe000[ 0.000000] Zone PFN ranges:[ 0.000000] DMA 0x00000010 -> 0x00001000[ 0.000000] Normal 0x00001000 -> 0x000377fe[ 0.000000] HighMem 0x000377fe -> 0x000bdd90[ 0.000000] Movable zone start PFN for each node[ 0.000000] Early memory PFN ranges[ 0.000000] 0: 0x00000010 -> 0x00000094[ 0.000000] 0: 0x00000100 -> 0x000bdd90[ 0.000000] On node 0 totalpages: 777492[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4c52200[ 0.000000] DMA zone: 32 pages used for memmap[ 0.000000] DMA zone: 0 pages reserved[ 0.000000] DMA zone: 3940 pages, LIFO batch:0[ 0.000000] Normal zone: 1744 pages used for memmap[ 0.000000] Normal zone: 221486 pages, LIFO batch:31[ 0.000000] HighMem zone: 4300 pages used for memmap[ 0.000000] HighMem zone: 545990 pages, LIFO batch:31[ 0.000000] Using APIC driver default[ 0.000000] ACPI: PM-Timer IO Port: 0x808[ 0.000000] ACPI: Local APIC address 0xfee00000[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)[ 0.000000] ACPI: IRQ0 used by override.[ 0.000000] ACPI: IRQ2 used by override.[ 0.000000] ACPI: IRQ9 used by override.[ 0.000000] Using ACPI (MADT) for SMP configuration information[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs[ 0.000000] nr_irqs_gsi: 40[ 0.000000] PM: Registered nosave memory: 0000000000094000 - 00000000000a0000[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e5000[ 0.000000] PM: Registered nosave memory: 00000000000e5000 - 0000000000100000[ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:3ed00000)[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 771416[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=b294cf37-537e-4f30-b8c8-f09c832a8049 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)[ 0.000000] Initializing CPU#0[ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240[ 0.000000] allocated 6220800 bytes of page_cgroup[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups[ 0.000000] Initializing HighMem for node 0 (000377fe:000bdd90)[ 0.000000] Memory: 3058296k/3110464k available (3495k kernel code, 51672k reserved, 1237k data, 416k init, 2201160k highmem)[ 0.000000] virtual kernel memory layout:[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.[ 0.000000] Preemptible hierarchical RCU implementation.[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.[ 0.000000] NR_IRQS:2304 nr_irqs:712 16[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000[ 0.000000] Interrupt pipeline (release #3)[ 0.000000] Console: colour VGA+ 80x25[ 0.000000] console [tty0] enabled[ 0.000000] hpet clockevent registered[ 0.000000] Fast TSC calibration using PIT[ 0.000000] Detected 3000.245 MHz processor.[ 0.004001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6000.49 BogoMIPS (lpj=12000980)[ 0.004005] pid_max: default: 32768 minimum: 301[ 0.004038] Security Framework initialized[ 0.004042] AppArmor: AppArmor disabled by boot time parameter[ 0.004056] Mount-cache hash table entries: 512[ 0.004215] Initializing cgroup subsys cpuacct[ 0.004217] Initializing cgroup subsys memory[ 0.004223] Initializing cgroup subsys devices[ 0.004225] Initializing cgroup subsys freezer[ 0.004227] Initializing cgroup subsys net_cls[ 0.004229] Initializing cgroup subsys blkio[ 0.004234] Initializing cgroup subsys perf_event[ 0.004255] CPU: Physical Processor ID: 0[ 0.004257] CPU: Processor Core ID: 0[ 0.004259] mce: CPU supports 6 MCE banks[ 0.004264] CPU0: Thermal monitoring enabled (TM2)[ 0.004308] ACPI: Core revision 20120320[ 0.010578] Enabling APIC mode: Flat. Using 1 I/O APICs[ 0.010914] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1[ 0.050608] CPU0: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz stepping 0a[ 0.052002] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver.[ 0.052002] ... version: 2[ 0.052002] ... bit width: 40[ 0.052002] ... generic registers: 2[ 0.052002] ... value mask: 000000ffffffffff[ 0.052002] ... max period: 000000007fffffff[ 0.052002] ... fixed-purpose events: 3[ 0.052002] ... event mask: 0000000700000003[ 0.060073] NMI watchdog: enabled, takes one hw-pmu counter.[ 0.072023] CPU 1 irqstacks, hard=f40d4000 soft=f40d6000[ 0.072025] Booting Node 0, Processors #1[ 0.008000] Initializing CPU#1[ 0.084030] NMI watchdog: enabled, takes one hw-pmu counter.[ 0.084064] Brought up 2 CPUs[ 0.084066] Total of 2 processors activated (12000.98 BogoMIPS).[ 0.086502] devtmpfs: initialized[ 0.086502] PM: Registering ACPI NVS region [mem 0xbdd9e000-0xbdddffff] (270336 bytes)[ 0.086502] dummy:[ 0.088040] NET: Registered protocol family 16[ 0.088154] ACPI: bus type pci registered[ 0.088200] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)[ 0.088203] PCI: not using MMCONFIG[ 0.088370] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=1[ 0.088371] PCI: Using configuration type 1 for base access[ 0.088787] bio: create slab <bio-0> at 0[ 0.088787] ACPI: Added _OSI(Module Device)[ 0.088787] ACPI: Added _OSI(Processor Device)[ 0.088787] ACPI: Added _OSI(3.0 _SCP Extensions)[ 0.088787] ACPI: Added _OSI(Processor Aggregator Device)[ 0.089206] ACPI: EC: Look up EC in DSDT[ 0.091573] ACPI: Executed 1 blocks of module-level executable AML code[ 0.095544] ACPI: Interpreter enabled[ 0.095550] ACPI: (supports S0 S3 S4 S5)[ 0.095570] ACPI: Using IOAPIC for interrupt routing[ 0.095590] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)[ 0.098748] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources[ 0.098750] PCI: Using MMCONFIG for extended config space[ 0.107321] ACPI: No dock devices found.[ 0.107326] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug[ 0.107501] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])[ 0.107641] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7][ 0.107644] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff][ 0.107646] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff][ 0.107648] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff][ 0.107650] pci_root PNP0A08:00: host bridge window [mem 0xbde00001-0xdfffffff][ 0.107652] pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xfed8ffff][ 0.107657] pci_root PNP0A08:00: ignoring host bridge window [mem 0x000d0000-0x000dffff] (conflicts with Adapter ROM [mem 0x000cc800-0x000d17ff])[ 0.107686] PCI host bridge to bus 0000:00[ 0.107688] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7][ 0.107690] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff][ 0.107692] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff][ 0.107695] pci_bus 0000:00: root bus resource [mem 0xbde00001-0xdfffffff][ 0.107697] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfed8ffff][ 0.107705] pci 0000:00:00.0: [8086:2e10] type 00 class 0x060000[ 0.107738] pci 0000:00:02.0: [8086:2e12] type 00 class 0x030000[ 0.107750] pci 0000:00:02.0: reg 10: [mem 0xfe800000-0xfebfffff 64bit][ 0.107756] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff 64bit pref][ 0.107761] pci 0000:00:02.0: reg 20: [io 0xdc00-0xdc07][ 0.107787] pci 0000:00:02.1: [8086:2e13] type 00 class 0x038000[ 0.107796] pci 0000:00:02.1: reg 10: [mem 0xfe600000-0xfe6fffff 64bit][ 0.107840] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000[ 0.107866] pci 0000:00:03.0: reg 10: [mem 0xfe7fbc00-0xfe7fbc0f 64bit][ 0.107938] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold[ 0.107956] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185[ 0.107968] pci 0000:00:03.2: reg 10: [io 0xd880-0xd887][ 0.107975] pci 0000:00:03.2: reg 14: [io 0xd800-0xd803][ 0.107981] pci 0000:00:03.2: reg 18: [io 0xd480-0xd487][ 0.107987] pci 0000:00:03.2: reg 1c: [io 0xd400-0xd403][ 0.107992] pci 0000:00:03.2: reg 20: [io 0xd080-0xd08f][ 0.108037] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002[ 0.108051] pci 0000:00:03.3: reg 10: [io 0xd000-0xd007][ 0.108059] pci 0000:00:03.3: reg 14: [mem 0xfe7fa000-0xfe7fafff][ 0.108134] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000[ 0.108150] pci 0000:00:19.0: reg 10: [mem 0xfe7c0000-0xfe7dffff][ 0.108158] pci 0000:00:19.0: reg 14: [mem 0xfe7f9000-0xfe7f9fff][ 0.108166] pci 0000:00:19.0: reg 18: [io 0xcc00-0xcc1f][ 0.108210] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold[ 0.108228] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300[ 0.108267] pci 0000:00:1a.0: reg 20: [io 0xc880-0xc89f][ 0.108305] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300[ 0.108343] pci 0000:00:1a.1: reg 20: [io 0xc800-0xc81f][ 0.108383] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300[ 0.108421] pci 0000:00:1a.2: reg 20: [io 0xc480-0xc49f][ 0.108467] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320[ 0.108487] pci 0000:00:1a.7: reg 10: [mem 0xfe7fb800-0xfe7fbbff][ 0.108553] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold[ 0.108577] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300[ 0.108591] pci 0000:00:1b.0: reg 10: [mem 0xfe7f4000-0xfe7f7fff 64bit][ 0.108639] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold[ 0.108659] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300[ 0.108697] pci 0000:00:1d.0: reg 20: [io 0xc400-0xc41f][ 0.108737] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300[ 0.108775] pci 0000:00:1d.1: reg 20: [io 0xc080-0xc09f][ 0.108814] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300[ 0.108852] pci 0000:00:1d.2: reg 20: [io 0xc000-0xc01f][ 0.108899] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320[ 0.108918] pci 0000:00:1d.7: reg 10: [mem 0xfe7fb400-0xfe7fb7ff][ 0.108984] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold[ 0.109003] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401[ 0.109053] pci 0000:00:1f.0: [8086:3a14] type 00 class 0x060100[ 0.109152] pci 0000:00:1f.2: [8086:2822] type 00 class 0x010400[ 0.109169] pci 0000:00:1f.2: reg 10: [io 0xbc00-0xbc07][ 0.109176] pci 0000:00:1f.2: reg 14: [io 0xb880-0xb883][ 0.109183] pci 0000:00:1f.2: reg 18: [io 0xb800-0xb807][ 0.109191] pci 0000:00:1f.2: reg 1c: [io 0xb480-0xb483][ 0.109198] pci 0000:00:1f.2: reg 20: [io 0xb400-0xb41f][ 0.109205] pci 0000:00:1f.2: reg 24: [mem 0xfe7f8800-0xfe7f8fff][ 0.109234] pci 0000:00:1f.2: PME# supported from D3hot[ 0.109252] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500[ 0.109266] pci 0000:00:1f.3: reg 10: [mem 0xfe7fb000-0xfe7fb0ff 64bit][ 0.109285] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f][ 0.109333] pci 0000:01:02.0: [1c00:2170] type 00 class 0x070101[ 0.109346] pci 0000:01:02.0: reg 10: [io 0xec00-0xec07][ 0.109356] pci 0000:01:02.0: reg 14: [io 0xe880-0xe887][ 0.109436] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)[ 0.109440] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff][ 0.109447] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)[ 0.109449] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)[ 0.109451] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)[ 0.109453] pci 0000:00:1e.0: bridge window [mem 0xbde00001-0xdfffffff] (subtractive decode)[ 0.109456] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfed8ffff] (subtractive decode)[ 0.109462] pci_bus 0000:00: on NUMA node 0[ 0.109465] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT][ 0.109661] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT][ 0.109882] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)[ 0.121419] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12 14 15)[ 0.121468] ACPI: PCI Interrupt Link [LNKB] (IRQs *5)[ 0.121510] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 *11 12 14 15)[ 0.121557] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 *7 10 11 12 14 15)[ 0.121603] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 14 *15)[ 0.121650] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12 *14 15)[ 0.121697] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 6 7 *10 11 12 14 15)[ 0.121743] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 6 7 10 *11 12 14 15)[ 0.121788] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none[ 0.121788] vgaarb: loaded[ 0.121788] vgaarb: bridge control possible 0000:00:02.0[ 0.121788] PCI: Using ACPI for IRQ routing[ 0.121788] PCI: pci_cache_line_size set to 64 bytes[ 0.121788] Expanded resource reserved due to conflict with PCI Bus 0000:00[ 0.121788] reserve RAM buffer: 0000000000094000 - 000000000009ffff[ 0.121788] reserve RAM buffer: 00000000bdd90000 - 00000000bfffffff[ 0.121788] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0[ 0.121788] hpet0: 8 comparators, 64-bit 14.318180 MHz counter[ 0.124021] Switching to clocksource hpet[ 0.124064] pnp: PnP ACPI init[ 0.124072] ACPI: bus type pnp registered[ 0.124154] pnp 00:00: [bus 00-ff][ 0.124156] pnp 00:00: [io 0x0cf8-0x0cff][ 0.124159] pnp 00:00: [io 0x0000-0x0cf7 window][ 0.124161] pnp 00:00: [io 0x0d00-0xffff window][ 0.124163] pnp 00:00: [mem 0x000a0000-0x000bffff window][ 0.124165] pnp 00:00: [mem 0x000d0000-0x000dffff window][ 0.124167] pnp 00:00: [mem 0xbde00001-0xdfffffff window][ 0.124169] pnp 00:00: [mem 0xf0000000-0xfed8ffff window][ 0.124206] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)[ 0.124216] pnp 00:01: [mem 0xfed14000-0xfed19fff][ 0.124218] pnp 00:01: [mem 0xfed90000-0xfed93fff][ 0.124253] system 00:01: [mem 0xfed14000-0xfed19fff] could not be reserved[ 0.124255] system 00:01: [mem 0xfed90000-0xfed93fff] has been reserved[ 0.124258] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)[ 0.124290] pnp 00:02: [dma 4][ 0.124292] pnp 00:02: [io 0x0000-0x000f][ 0.124294] pnp 00:02: [io 0x0081-0x0083][ 0.124296] pnp 00:02: [io 0x0087][ 0.124298] pnp 00:02: [io 0x0089-0x008b][ 0.124300] pnp 00:02: [io 0x008f][ 0.124301] pnp 00:02: [io 0x00c0-0x00df][ 0.124322] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)[ 0.124332] pnp 00:03: [io 0x0070-0x0071][ 0.124338] pnp 00:03: [irq 8][ 0.124359] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)[ 0.124367] pnp 00:04: [io 0x0061][ 0.124389] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)[ 0.124398] pnp 00:05: [io 0x00f0-0x00ff][ 0.124402] pnp 00:05: [irq 13][ 0.124423] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)[ 0.125120] pnp 00:06: [io 0x02f8-0x02ff][ 0.125125] pnp 00:06: [irq 3][ 0.125127] pnp 00:06: [dma 0 disabled][ 0.125197] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)[ 0.126235] pnp 00:07: [io 0x0060][ 0.126237] pnp 00:07: [io 0x0064][ 0.126242] pnp 00:07: [irq 12][ 0.126270] pnp 00:07: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)[ 0.126410] pnp 00:08: [io 0x0000-0xffffffff disabled][ 0.126414] pnp 00:08: [io 0x0a00-0x0a0f][ 0.126416] pnp 00:08: [io 0x0a10-0x0a1f][ 0.126417] pnp 00:08: [io 0x0a20-0x0a2f][ 0.126419] pnp 00:08: [io 0x0a30-0x0a3f][ 0.126458] system 00:08: [io 0x0a00-0x0a0f] has been reserved[ 0.126461] system 00:08: [io 0x0a10-0x0a1f] has been reserved[ 0.126463] system 00:08: [io 0x0a20-0x0a2f] has been reserved[ 0.126465] system 00:08: [io 0x0a30-0x0a3f] has been reserved[ 0.126468] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)[ 0.126583] pnp 00:09: [io 0x0010-0x001f][ 0.126585] pnp 00:09: [io 0x0022-0x003f][ 0.126587] pnp 00:09: [io 0x0044-0x005f][ 0.126589] pnp 00:09: [io 0x0062-0x0063][ 0.126591] pnp 00:09: [io 0x0065-0x006f][ 0.126592] pnp 00:09: [io 0x0072-0x007f][ 0.126594] pnp 00:09: [io 0x0080][ 0.126596] pnp 00:09: [io 0x0084-0x0086][ 0.126598] pnp 00:09: [io 0x0088][ 0.126599] pnp 00:09: [io 0x008c-0x008e][ 0.126601] pnp 00:09: [io 0x0090-0x009f][ 0.126603] pnp 00:09: [io 0x00a2-0x00bf][ 0.126605] pnp 00:09: [io 0x00e0-0x00ef][ 0.126606] pnp 00:09: [io 0x04d0-0x04d1][ 0.126608] pnp 00:09: [io 0x04c0-0x04cf][ 0.126610] pnp 00:09: [io 0x04d2-0x04ff][ 0.126612] pnp 00:09: [io 0x0800-0x087f][ 0.126614] pnp 00:09: [io 0x0000-0xffffffff disabled][ 0.126615] pnp 00:09: [io 0x0480-0x04bf][ 0.126617] pnp 00:09: [mem 0xfed1c000-0xfed1ffff][ 0.126619] pnp 00:09: [mem 0xfed20000-0xfed3ffff][ 0.126621] pnp 00:09: [mem 0xfed45000-0xfed8ffff][ 0.126673] system 00:09: [io 0x04d0-0x04d1] has been reserved[ 0.126675] system 00:09: [io 0x04c0-0x04cf] has been reserved[ 0.126677] system 00:09: [io 0x04d2-0x04ff] has been reserved[ 0.126680] system 00:09: [io 0x0800-0x087f] has been reserved[ 0.126682] system 00:09: [io 0x0480-0x04bf] has been reserved[ 0.126684] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved[ 0.126687] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved[ 0.126689] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved[ 0.126692] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)[ 0.126747] pnp 00:0a: [mem 0xfed00000-0xfed003ff][ 0.126772] pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active)[ 0.126823] pnp 00:0b: [mem 0xffb00000-0xffbfffff][ 0.126825] pnp 00:0b: [mem 0xfff00000-0xffffffff][ 0.126848] pnp 00:0b: Plug and Play ACPI device, IDs INT0800 (active)[ 0.126889] pnp 00:0c: [mem 0xffc00000-0xffefffff][ 0.126926] system 00:0c: [mem 0xffc00000-0xffefffff] has been reserved[ 0.126929] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)[ 0.127013] pnp 00:0d: [mem 0xfec00000-0xfec00fff][ 0.127015] pnp 00:0d: [mem 0xfee00000-0xfee00fff][ 0.127055] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved[ 0.127057] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved[ 0.127060] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)[ 0.127751] pnp 00:0e: [io 0x03f8-0x03ff][ 0.127756] pnp 00:0e: [irq 4][ 0.127758] pnp 00:0e: [dma 0 disabled][ 0.127835] pnp 00:0e: Plug and Play ACPI device, IDs PNP0501 (active)[ 0.127886] pnp 00:0f: [mem 0xe0000000-0xefffffff][ 0.127927] system 00:0f: [mem 0xe0000000-0xefffffff] has been reserved[ 0.127929] system 00:0f: Plug and Play ACPI device, IDs PNP0c02 (active)[ 0.128010] pnp 00:10: [mem 0xfed40000-0xfed44fff][ 0.128049] pnp 00:10: Plug and Play ACPI device, IDs PNP0c31 (active)[ 0.128168] pnp 00:11: [mem 0x00000000-0x0009ffff][ 0.128171] pnp 00:11: [mem 0x000c0000-0x000cffff][ 0.128173] pnp 00:11: [mem 0x000e0000-0x000fffff][ 0.128175] pnp 00:11: [mem 0x00100000-0xbde00000][ 0.128177] pnp 00:11: [mem 0xfed90000-0xffffffff][ 0.128225] system 00:11: [mem 0x00000000-0x0009ffff] could not be reserved[ 0.128228] system 00:11: [mem 0x000c0000-0x000cffff] could not be reserved[ 0.128230] system 00:11: [mem 0x000e0000-0x000fffff] could not be reserved[ 0.128233] system 00:11: [mem 0x00100000-0xbde00000] could not be reserved[ 0.128236] system 00:11: [mem 0xfed90000-0xffffffff] could not be reserved[ 0.128238] system 00:11: Plug and Play ACPI device, IDs PNP0c01 (active)[ 0.128370] pnp: PnP ACPI: found 18 devices[ 0.128372] ACPI: ACPI bus type pnp unregistered[ 0.128374] PnPBIOS: Disabled by ACPI PNP[ 0.164734] pci 0000:00:1e.0: PCI bridge to [bus 01-01][ 0.164737] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff][ 0.164752] pci 0000:00:1e.0: setting latency timer to 64[ 0.164755] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7][ 0.164757] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff][ 0.164759] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff][ 0.164761] pci_bus 0000:00: resource 7 [mem 0xbde00001-0xdfffffff][ 0.164763] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfed8ffff][ 0.164765] pci_bus 0000:01: resource 0 [io 0xe000-0xefff][ 0.164767] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7][ 0.164769] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff][ 0.164771] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff][ 0.164773] pci_bus 0000:01: resource 7 [mem 0xbde00001-0xdfffffff][ 0.164775] pci_bus 0000:01: resource 8 [mem 0xf0000000-0xfed8ffff][ 0.164831] NET: Registered protocol family 2[ 0.164879] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)[ 0.165012] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)[ 0.165244] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)[ 0.165353] TCP: Hash tables configured (established 131072 bind 65536)[ 0.165354] TCP: reno registered[ 0.165357] UDP hash table entries: 512 (order: 2, 16384 bytes)[ 0.165362] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)[ 0.165419] NET: Registered protocol family 1[ 0.165428] pci 0000:00:02.0: Boot video device[ 0.165609] PCI: CLS 32 bytes, default 64[ 0.165639] Unpacking initramfs...[ 0.389816] Freeing initrd memory: 14268k freed[ 0.394398] audit: initializing netlink socket (disabled)[ 0.394412] type=2000 audit(1697806378.392:1): initialized[ 0.403535] highmem bounce pool size: 64 pages[ 0.403539] HugeTLB registered 4 MB page size, pre-allocated 0 pages[ 0.403692] VFS: Disk quotas dquot_6.5.2[ 0.403714] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)[ 0.403775] msgmni has been set to 1701[ 0.403906] alg: No test for stdrng (krng)[ 0.403928] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)[ 0.403931] io scheduler noop registered[ 0.403933] io scheduler deadline registered[ 0.403947] io scheduler cfq registered (default)[ 0.404030] pci_hotplug: PCI Hot Plug PCI Core version: 0.5[ 0.404045] pciehp: PCI Express Hot Plug Controller Driver version: 0.4[ 0.404047] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5[ 0.404368] GHES: HEST is not enabled![ 0.404378] isapnp: Scanning for PnP cards...[ 0.757278] isapnp: No Plug & Play device found[ 0.757317] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled[ 0.777635] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A[ 0.797964] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A[ 0.818465] 00:06: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A[ 0.838883] 00:0e: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A[ 0.859043] 0000:00:03.3: ttyS2 at I/O 0xd000 (irq = 17) is a 16550A[ 0.859191] Linux agpgart interface v0.103[ 0.859292] agpgart-intel 0000:00:00.0: Intel Q45/Q43 Chipset[ 0.859341] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable[ 0.860767] agpgart-intel 0000:00:00.0: detected 32768K stolen memory[ 0.860860] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000[ 0.860982] i8042: PNP: PS/2 Controller [PNP0f03:PS2M] at 0x60,0x64 irq 12[ 0.860984] i8042: PNP: PS/2 controller doesn't have KBD irq; using default 1[ 0.861351] serio: i8042 KBD port at 0x60,0x64 irq 1[ 0.861378] serio: i8042 AUX port at 0x60,0x64 irq 12[ 0.861464] mousedev: PS/2 mouse device common for all mice[ 0.861498] rtc_cmos 00:03: RTC can wake from S4[ 0.861603] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0[ 0.861625] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs[ 0.861729] TCP: cubic registered[ 0.861771] NET: Registered protocol family 10[ 0.861951] Mobile IPv6[ 0.861954] NET: Registered protocol family 17[ 0.861957] Registering the dns_resolver key type[ 0.862001] Using IPI No-Shortcut mode[ 0.862080] PM: Hibernation image not present or could not be loaded.[ 0.862091] registered taskstats version 1[ 0.862397] rtc_cmos 00:03: setting system clock to 2023-10-20 12:52:59 UTC (1697806379)[ 0.862472] Freeing unused kernel memory: 416k freed[ 0.862602] Write protecting the kernel text: 3496k[ 0.862620] Write protecting the kernel read-only data: 984k[ 0.871094] udevd[49]: starting version 175[ 0.887658] usbcore: registered new interface driver usbfs[ 0.887679] usbcore: registered new interface driver hub[ 0.896666] microcode: CPU0 sig=0x1067a, pf=0x1, revision=0xa07[ 0.903263] usbcore: registered new device driver usb[ 0.903745] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver[ 0.903803] ehci_hcd 0000:00:1a.7: setting latency timer to 64[ 0.903807] ehci_hcd 0000:00:1a.7: EHCI Host Controller[ 0.903828] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1[ 0.903851] ehci_hcd 0000:00:1a.7: debug port 1[ 0.907728] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported[ 0.907746] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfe7fb800[ 0.911879] SCSI subsystem initialized[ 0.914029] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k[ 0.914032] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.[ 0.917397] libata version 3.00 loaded.[ 0.918054] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00[ 0.918093] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002[ 0.918096] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 0.918098] usb usb1: Product: EHCI Host Controller[ 0.918100] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd[ 0.918102] usb usb1: SerialNumber: 0000:00:1a.7[ 0.918404] hub 1-0:1.0: USB hub found[ 0.918410] hub 1-0:1.0: 6 ports detected[ 0.918513] e1000e 0000:00:19.0: setting latency timer to 64[ 0.918565] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode[ 0.920315] uhci_hcd: USB Universal Host Controller Interface driver[ 0.949356] microcode: CPU0 updated to revision 0xa0b, date = 2010-09-28[ 0.950417] microcode: CPU1 sig=0x1067a, pf=0x1, revision=0xa07[ 0.956006] microcode: CPU1 updated to revision 0xa0b, date = 2010-09-28[ 0.957033] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba[ 1.116074] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:25:11:1a:ea:24[ 1.116077] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection[ 1.116111] e1000e 0000:00:19.0: eth0: MAC: 8, PHY: 8, PBA No: FFFFFF-0FF[ 1.116167] ata_generic 0000:00:03.2: setting latency timer to 64[ 1.116501] scsi0 : ata_generic[ 1.116819] scsi1 : ata_generic[ 1.116860] ata1: PATA max UDMA/100 cmd 0xd880 ctl 0xd800 bmdma 0xd080 irq 18[ 1.116863] ata2: PATA max UDMA/100 cmd 0xd480 ctl 0xd400 bmdma 0xd088 irq 18[ 1.116910] ehci_hcd 0000:00:1d.7: setting latency timer to 64[ 1.116913] ehci_hcd 0000:00:1d.7: EHCI Host Controller[ 1.116922] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2[ 1.116945] ehci_hcd 0000:00:1d.7: debug port 1[ 1.120835] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported[ 1.120851] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfe7fb400[ 1.240018] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00[ 1.240059] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002[ 1.240063] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.240066] usb usb2: Product: EHCI Host Controller[ 1.240068] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd[ 1.240071] usb usb2: SerialNumber: 0000:00:1d.7[ 1.240209] hub 2-0:1.0: USB hub found[ 1.240214] hub 2-0:1.0: 6 ports detected[ 1.240290] uhci_hcd 0000:00:1a.0: setting latency timer to 64[ 1.240293] uhci_hcd 0000:00:1a.0: UHCI Host Controller[ 1.240300] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3[ 1.240329] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000c880[ 1.240355] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001[ 1.240357] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.240359] usb usb3: Product: UHCI Host Controller[ 1.240361] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd[ 1.240363] usb usb3: SerialNumber: 0000:00:1a.0[ 1.240486] hub 3-0:1.0: USB hub found[ 1.240491] hub 3-0:1.0: 2 ports detected[ 1.240558] uhci_hcd 0000:00:1a.1: setting latency timer to 64[ 1.240561] uhci_hcd 0000:00:1a.1: UHCI Host Controller[ 1.240567] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4[ 1.240596] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000c800[ 1.240622] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001[ 1.240624] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.240626] usb usb4: Product: UHCI Host Controller[ 1.240628] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd[ 1.240630] usb usb4: SerialNumber: 0000:00:1a.1[ 1.240770] hub 4-0:1.0: USB hub found[ 1.240774] hub 4-0:1.0: 2 ports detected[ 1.240841] uhci_hcd 0000:00:1a.2: setting latency timer to 64[ 1.240844] uhci_hcd 0000:00:1a.2: UHCI Host Controller[ 1.240851] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5[ 1.240880] uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000c480[ 1.240907] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001[ 1.240909] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.240911] usb usb5: Product: UHCI Host Controller[ 1.240912] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd[ 1.240914] usb usb5: SerialNumber: 0000:00:1a.2[ 1.240994] hub 5-0:1.0: USB hub found[ 1.240998] hub 5-0:1.0: 2 ports detected[ 1.241064] uhci_hcd 0000:00:1d.0: setting latency timer to 64[ 1.241067] uhci_hcd 0000:00:1d.0: UHCI Host Controller[ 1.241074] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6[ 1.241093] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000c400[ 1.241120] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001[ 1.241122] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.241124] usb usb6: Product: UHCI Host Controller[ 1.241126] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd[ 1.241128] usb usb6: SerialNumber: 0000:00:1d.0[ 1.241540] hub 6-0:1.0: USB hub found[ 1.241544] hub 6-0:1.0: 2 ports detected[ 1.241611] uhci_hcd 0000:00:1d.1: setting latency timer to 64[ 1.241615] uhci_hcd 0000:00:1d.1: UHCI Host Controller[ 1.241621] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7[ 1.241642] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000c080[ 1.241669] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001[ 1.241671] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.241673] usb usb7: Product: UHCI Host Controller[ 1.241675] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd[ 1.241677] usb usb7: SerialNumber: 0000:00:1d.1[ 1.242386] hub 7-0:1.0: USB hub found[ 1.242391] hub 7-0:1.0: 2 ports detected[ 1.242455] uhci_hcd 0000:00:1d.2: setting latency timer to 64[ 1.242458] uhci_hcd 0000:00:1d.2: UHCI Host Controller[ 1.242465] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8[ 1.242485] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c000[ 1.242512] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001[ 1.242514] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.242516] usb usb8: Product: UHCI Host Controller[ 1.242518] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd[ 1.242520] usb usb8: SerialNumber: 0000:00:1d.2[ 1.243057] hub 8-0:1.0: USB hub found[ 1.243061] hub 8-0:1.0: 2 ports detected[ 1.243131] ahci 0000:00:1f.2: version 3.0[ 1.243151] ahci 0000:00:1f.2: controller can't do SNTF, turning off CAP_SNTF[ 1.243175] ahci: SSS flag set, parallel bus scan disabled[ 1.243203] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode[ 1.243206] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems sxs[ 1.243209] ahci 0000:00:1f.2: setting latency timer to 64[ 1.280695] scsi2 : ahci[ 1.280788] scsi3 : ahci[ 1.280878] scsi4 : ahci[ 1.280969] scsi5 : ahci[ 1.281058] scsi6 : ahci[ 1.281148] scsi7 : ahci[ 1.281328] ata3: SATA max UDMA/133 abar m2048@0xfe7f8800 port 0xfe7f8900 irq 19[ 1.281331] ata4: SATA max UDMA/133 abar m2048@0xfe7f8800 port 0xfe7f8980 irq 19[ 1.281334] ata5: SATA max UDMA/133 abar m2048@0xfe7f8800 port 0xfe7f8a00 irq 19[ 1.281337] ata6: SATA max UDMA/133 abar m2048@0xfe7f8800 port 0xfe7f8a80 irq 19[ 1.281339] ata7: SATA max UDMA/133 abar m2048@0xfe7f8800 port 0xfe7f8b00 irq 19[ 1.281341] ata8: SATA max UDMA/133 abar m2048@0xfe7f8800 port 0xfe7f8b80 irq 19[ 1.392050] Refined TSC clocksource calibration: 2999.952 MHz.[ 1.392056] Switching to clocksource tsc[ 1.600017] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)[ 1.614132] ata3.00: ATA-8: WDC WD2500AAKX-75U6AA0, 19.01H19, max UDMA/133[ 1.614136] ata3.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA[ 1.615134] ata3.00: configured for UDMA/133[ 1.615221] scsi 2:0:0:0: Direct-Access ATA WDC WD2500AAKX-7 19.0 PQ: 0 ANSI: 5[ 1.668014] usb 3-2: new full-speed USB device number 2 using uhci_hcd[ 1.850361] usb 3-2: New USB device found, idVendor=046d, idProduct=c534[ 1.850365] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0[ 1.850368] usb 3-2: Product: USB Receiver[ 1.850371] usb 3-2: Manufacturer: Logitech[ 1.862770] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/input/input0[ 1.862811] generic-usb 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.0-2/input0[ 1.866343] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.1/input/input1[ 1.866429] generic-usb 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.0-2/input1[ 1.866516] usbcore: registered new interface driver usbhid[ 1.866518] usbhid: USB HID core driver[ 1.932018] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)[ 1.935027] ata4.00: ATAPI: HL-DT-ST DVDRAM GH40F, MG01, max UDMA/100[ 1.938899] ata4.00: configured for UDMA/100[ 1.949614] scsi 3:0:0:0: CD-ROM HL-DT-ST DVDRAM GH40F MG01 PQ: 0 ANSI: 5[ 2.096011] usb 8-2: new full-speed USB device number 2 using uhci_hcd[ 2.268016] ata5: SATA link down (SStatus 0 SControl 300)[ 2.278520] usb 8-2: New USB device found, idVendor=046d, idProduct=c52f[ 2.278524] usb 8-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0[ 2.278526] usb 8-2: Product: USB Receiver[ 2.278529] usb 8-2: Manufacturer: Logitech[ 2.286937] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.0/input/input2[ 2.286998] generic-usb 0003:046D:C52F.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.2-2/input0[ 2.291628] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.1/input/input3[ 2.291709] generic-usb 0003:046D:C52F.0004: input,hiddev0,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.2-2/input1[ 2.588016] ata6: SATA link down (SStatus 0 SControl 300)[ 2.908016] ata7: SATA link down (SStatus 0 SControl 300)[ 3.228015] ata8: SATA link down (SStatus 0 SControl 300)[ 3.236073] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)[ 3.236118] sd 2:0:0:0: [sda] Write Protect is off[ 3.236121] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00[ 3.236140] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA[ 3.244290] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray[ 3.244294] cdrom: Uniform CD-ROM driver Revision: 3.20[ 3.244425] sr 3:0:0:0: Attached scsi CD-ROM sr0[ 3.281917] sda: sda1 sda2 < sda5 sda6 sda7 >[ 3.282275] sd 2:0:0:0: [sda] Attached SCSI disk[ 3.283541] sd 2:0:0:0: Attached scsi generic sg0 type 0[ 3.283573] sr 3:0:0:0: Attached scsi generic sg1 type 5[ 8.782558] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)[ 10.038430] udevd[396]: starting version 175[ 10.187941] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4[ 10.187948] ACPI: Power Button [PWRB][ 10.187996] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5[ 10.188058] ACPI: Power Button [PWRF][ 10.195067] tpm_tis 00:10: 1.2 TPM (device-id 0x1040, rev-id 4)[ 10.195070] tpm_tis 00:10: Intel iTPM workaround enabled[ 10.324015] tpm_tis 00:10: TPM is disabled/deactivated (0x7)[ 10.336662] wmi: Mapper loaded[ 10.729705] iTCO_vendor_support: vendor-support=0[ 10.780037] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07[ 10.780100] iTCO_wdt: Found a ICH10DO TCO device (Version=2, TCOBASE=0x0860)[ 10.780338] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)[ 10.844731] hda_codec: ALC888: SKU not ready 0x411111f0[ 10.847673] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6[ 10.855332] [drm] Initialized drm 1.1.0 20060810[ 10.925915] input: HDA Intel HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7[ 10.926057] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8[ 10.926122] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9[ 10.926185] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10[ 10.926243] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11[ 10.926300] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12[ 10.926358] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13[ 10.926415] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14[ 10.926471] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15[ 10.927004] i915 0000:00:02.0: setting latency timer to 64[ 10.944903] mtrr: type mismatch for d0000000,10000000 old: write-back new: write-combining[ 10.944906] [drm] MTRR allocation failed. Graphics performance may suffer.[ 10.945062] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).[ 10.945064] [drm] Driver supports precise vblank timestamp query.[ 10.945095] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem[ 11.018853] fbcon: inteldrmfb (fb0) is primary device[ 11.059978] Console: switching to colour frame buffer device 180x56[ 11.063264] fb0: inteldrmfb frame buffer device[ 11.063265] drm: registered panic notifier[ 11.063275] No ACPI video bus found[ 11.063308] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0[ 12.350869] EXT4-fs (sda7): re-mounted. Opts: (null)[ 12.495276] EXT4-fs (sda7): re-mounted. Opts: errors=remount-ro[ 12.552512] loop: module loaded[ 13.445727] RPC: Registered named UNIX socket transport module.[ 13.445729] RPC: Registered udp transport module.[ 13.445731] RPC: Registered tcp transport module.[ 13.445732] RPC: Registered tcp NFSv4.1 backchannel transport module.[ 13.475013] FS-Cache: Loaded[ 13.486903] NFS: Registering the id_resolver key type[ 13.486914] FS-Cache: Netfs 'nfs' registered for caching[ 13.490414] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).[ 15.136301] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input16[ 15.706872] Bluetooth: Core ver 2.16[ 15.706884] NET: Registered protocol family 31[ 15.706885] Bluetooth: HCI device and connection manager initialized[ 15.706887] Bluetooth: HCI socket layer initialized[ 15.706889] Bluetooth: L2CAP socket layer initialized[ 15.706893] Bluetooth: SCO socket layer initialized[ 15.763036] Bluetooth: BNEP (Ethernet Emulation) ver 1.3[ 15.763038] Bluetooth: BNEP filters: protocol multicast[ 15.771031] Bluetooth: RFCOMM TTY layer initialized[ 15.771034] Bluetooth: RFCOMM socket layer initialized[ 15.771036] Bluetooth: RFCOMM ver 1.11[ 15.871317] lp: driver loaded but no devices found[ 15.893114] ppdev: user-space parallel port driver[ 17.122438] ADDRCONF(NETDEV_UP): eth0: link is not ready[ 70.338149] classicladder[3411]: segfault at 8 ip b77909bd sp bfe077f0 error 6 in liblinuxcnchal.so.0[b778c000+9000][ 109.917809] I-pipe: head domain RTAI registered.[ 109.917813] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .[ 109.917835] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).[ 109.917837] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20831527, CLK_FREQ 3000245000, CPU_FREQ 3000245000[ 109.917840] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312[ 109.917842] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20831527, 20831527, 16319000[ 109.940227] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.[ 109.940246] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.[ 109.940250] RTAI[sched]: hard timer type/freq = APIC/20831527(Hz); default timing: oneshot; linear timed lists.[ 109.940252] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3000245000 hz.[ 109.940254] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.[ 109.953553] RTAI[math]: loaded.[ 110.110012] config string '0 out'[ 110.110799] PARPORT: ERROR: linux parport 0 not found[ 112.456150] RTAI[math]: unloaded.[ 112.457275] SCHED releases registered named ALIEN PEDV$D[ 112.459131] RTAI[malloc]: unloaded.[ 112.556010] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).[ 112.557197] I-pipe: head domain RTAI unregistered.[ 112.557228] RTAI[hal]: unmounted.[ 136.136217] I-pipe: head domain RTAI registered.[ 136.136222] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .[ 136.136245] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).[ 136.136247] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20831527, CLK_FREQ 3000245000, CPU_FREQ 3000245000[ 136.136250] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312[ 136.136252] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20831527, 20831527, 20804250[ 136.141483] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.[ 136.141503] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.[ 136.141507] RTAI[sched]: hard timer type/freq = APIC/20831527(Hz); default timing: oneshot; linear timed lists.[ 136.141509] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3000245000 hz.[ 136.141511] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.[ 136.145630] RTAI[math]: loaded.[ 136.288284] config string '0 out'[ 136.289129] PARPORT: ERROR: linux parport 0 not found[ 138.528608] RTAI[math]: unloaded.[ 138.529788] SCHED releases registered named ALIEN PEDV$D[ 138.532982] RTAI[malloc]: unloaded.[ 138.632010] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).[ 138.633193] I-pipe: head domain RTAI unregistered.[ 138.633219] RTAI[hal]: unmounted.[ 284.988015] usb 2-3: new high-speed USB device number 3 using ehci_hcd[ 285.122368] usb 2-3: New USB device found, idVendor=05ac, idProduct=12a8[ 285.122372] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3[ 285.122375] usb 2-3: Product: iPhone[ 285.122378] usb 2-3: Manufacturer: Apple Inc.[ 285.122380] usb 2-3: SerialNumber: 00008030001909943A90402E[ 285.249415] ipheth 2-3:4.2: Apple iPhone USB Ethernet device attached[ 285.249445] usbcore: registered new interface driver ipheth[ 290.832006]
[ cut here ]
[ 290.832015] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/net/sched/sch_generic.c:256 dev_watchdog+0x1e7/0x1f0()[ 290.832018] Hardware name: Veriton M670G/M670 [ 290.832021] NETDEV WATCHDOG: eth1 (ipheth): transmit queue 0 timed out[ 290.832023] Modules linked in: ipheth parport_pc ppdev lp parport rfcomm bnep bluetooth rfkill uinput nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop joydev snd_hda_codec_hdmi i915 video drm_kms_helper drm snd_hda_codec_realtek thermal_sys i2c_algo_bit iTCO_wdt iTCO_vendor_support snd_hda_intel coretemp snd_hda_codec snd_hwdep snd_pcm psmouse i2c_i801 evdev serio_raw i2c_core snd_page_alloc snd_seq snd_seq_device snd_timer snd wmi soundcore tpm_tis tpm tpm_bios button ext4 crc16 jbd2 mbcache sg sd_mod crc_t10dif sr_mod cdrom usbhid hid ahci libahci uhci_hcd ata_generic libata e1000e scsi_mod ehci_hcd microcode usbcore usb_common [last unloaded: rtai_hal][ 290.832102] Pid: 0, comm: swapper/0 Tainted: G O 3.4-9-rtai-686-pae #1[ 290.832104] Call Trace:[ 290.832110] [<c102adf8>] ? warn_slowpath_common+0x78/0xb0[ 290.832114] [<c12a7357>] ? dev_watchdog+0x1e7/0x1f0[ 290.832118] [<c12a7357>] ? dev_watchdog+0x1e7/0x1f0[ 290.832122] [<c102aec3>] ? warn_slowpath_fmt+0x33/0x40[ 290.832126] [<c12a7357>] ? dev_watchdog+0x1e7/0x1f0[ 290.832130] [<c12a7170>] ? qdisc_reset+0x30/0x30[ 290.832134] [<c10353d5>] ? run_timer_softirq+0xd5/0x200[ 290.832138] [<c1030cc5>] ? __do_softirq+0x75/0x110[ 290.832142] [<c1030c50>] ? local_bh_enable_ip+0xb0/0xb0[ 290.832146] [<c1030c50>] ? local_bh_enable_ip+0xb0/0xb0[ 290.832149] <IRQ> [<c101c050>] ? lapic_get_maxlvt+0x30/0x30[ 290.832156] [<c1030fee>] ? irq_exit+0x6e/0x90[ 290.832160] [<c101c08d>] ? smp_apic_timer_interrupt+0x3d/0x70[ 290.832164] [<c1003c10>] ? arch_irq_stat+0x10/0x10[ 290.832168] [<c101aa72>] ? __ipipe_do_IRQ+0x42/0x60[ 290.832171] [<c101c050>] ? lapic_get_maxlvt+0x30/0x30[ 290.832175] [<c101aa77>] ? __ipipe_do_IRQ+0x47/0x60[ 290.832180] [<c1010060>] ? p6_pmu_disable_event+0x10/0x50[ 290.832184] [<c1097b8a>] ? __ipipe_do_sync_stage+0x14a/0x150[ 290.832187] [<c1097f24>] ? __ipipe_dispatch_irq+0xe4/0x1a0[ 290.832191] [<c101b03b>] ? __ipipe_handle_irq+0x5b/0x160[ 290.832196] [<c13645d1>] ? apic_timer_interrupt+0x31/0x40[ 290.832200] [<c101a98c>] ? __ipipe_halt_root+0x1c/0x30[ 290.832210] [<c1008d96>] ? default_idle+0x26/0x50[ 290.832212] [<c10097db>] ? cpu_idle+0x9b/0xe0[ 290.832215] [<c14a076f>] ? start_kernel+0x3b3/0x3b8[ 290.832218] [<c14a020a>] ? repair_env_string+0x4d/0x4d[ 290.832219] ---[ end trace 69cbc04a4e6a86b6 ]---[ 290.832221] ipheth: ipheth_tx_timeout: TX timeout[ 296.048007] eth1: no IPv6 routers present[ 301.008007] ipheth: ipheth_tx_timeout: TX timeout[ 306.016008] ipheth: ipheth_tx_timeout: TX timeout[ 316.016006] ipheth: ipheth_tx_timeout: TX timeout[ 326.016006] ipheth: ipheth_tx_timeout: TX timeout[ 336.016006] ipheth: ipheth_tx_timeout: TX timeout[ 344.928005] eth1: no IPv6 routers present[ 346.016006] ipheth: ipheth_tx_timeout: TX timeout[ 356.016005] ipheth: ipheth_tx_timeout: TX timeout[ 366.016007] ipheth: ipheth_tx_timeout: TX timeout[ 376.016007] ipheth: ipheth_tx_timeout: TX timeout[ 386.016007] ipheth: ipheth_tx_timeout: TX timeout[ 392.704007] eth1: no IPv6 routers present[ 396.016007] ipheth: ipheth_tx_timeout: TX timeout[ 404.256008] eth1: no IPv6 routers present[ 406.016006] ipheth: ipheth_tx_timeout: TX timeout[ 415.010564] usb 2-3: USB disconnect, device number 3[ 415.011291] ipheth: ipheth_tx: usb_submit_urb: -19[ 415.020513] ipheth 2-3:4.2: Apple iPhone USB Ethernet now disconnected[ 416.884014] usb 2-3: new high-speed USB device number 4 using ehci_hcd[ 417.017792] usb 2-3: New USB device found, idVendor=05ac, idProduct=12a8[ 417.017796] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3[ 417.017799] usb 2-3: Product: iPhone[ 417.017802] usb 2-3: Manufacturer: Apple Inc.[ 417.017804] usb 2-3: SerialNumber: 00008030001909943A90402E[ 417.025875] ipheth 2-3:4.2: Apple iPhone USB Ethernet device attached[ 427.008009] ipheth: ipheth_tx_timeout: TX timeout[ 753.432941] I-pipe: head domain RTAI registered.[ 753.432945] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .[ 753.432975] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).[ 753.432977] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20831527, CLK_FREQ 3000245000, CPU_FREQ 3000245000[ 753.432979] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312[ 753.432982] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20831527, 20831527, 20807750[ 753.439309] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.[ 753.439330] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.[ 753.439333] RTAI[sched]: hard timer type/freq = APIC/20831527(Hz); default timing: oneshot; linear timed lists.[ 753.439336] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3000245000 hz.[ 753.439338] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.[ 753.446377] RTAI[math]: loaded.[ 753.489743] config string '0 out'[ 753.490515] PARPORT: ERROR: linux parport 0 not found[ 755.744867] RTAI[math]: unloaded.[ 755.746115] SCHED releases registered named ALIEN PEDV$D[ 755.749678] RTAI[malloc]: unloaded.[ 755.848014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).[ 755.849218] I-pipe: head domain RTAI unregistered.[ 755.849244] RTAI[hal]: unmounted.[ 777.495631] I-pipe: head domain RTAI registered.[ 777.495635] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .[ 777.495659] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).[ 777.495661] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20831527, CLK_FREQ 3000245000, CPU_FREQ 3000245000[ 777.495663] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312[ 777.495666] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20831527, 20831527, 19883750[ 777.500895] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.[ 777.500917] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.[ 777.500921] RTAI[sched]: hard timer type/freq = APIC/20831527(Hz); default timing: oneshot; linear timed lists.[ 777.500924] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3000245000 hz.[ 777.500925] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.[ 777.504984] RTAI[math]: loaded.[ 777.647659] config string '0 out'[ 777.648597] PARPORT: ERROR: linux parport 0 not found[ 779.887260] RTAI[math]: unloaded.[ 779.888384] SCHED releases registered named ALIEN PEDV$D[ 779.892403] RTAI[malloc]: unloaded.[ 779.992015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).[ 779.993238] I-pipe: head domain RTAI unregistered.[ 779.993265] RTAI[hal]: unmounted.
[ cut here ]
- rmu
- Thank you received: 101
27 Apr 2023 08:07 #270044
by rmu
Replied by rmu on topic Error message
Seems like your parallel port disappeared. Maybe somebody disabled it in BIOS? Probably best to ask whoever you bought the computer from.
The following user(s) said Thank You: gwiz
- gwiz
28 Apr 2023 10:27 #270107
by gwiz
Replied by gwiz on topic Error message
thank you very much, i was able to fix it with your advice!
- szl
17 Jul 2023 04:37 #275616
by szl
Replied by szl on topic Error message
I use a source install, executing in linuxcnc-dev/src/ ./configure --with-realtime=uspace and then I get No module named 'git', I use sudo apt-get install python3-git and I still get this error.
- Thank you received: 4138
17 Jul 2023 04:55 #275618
Replied by rodw on topic Error message
try
sudo apt-get install git
Time to create page: 0.231 seconds
