7I92 Board Fails HM2 Registration
- 2wire078
- Visitor
29 Apr 2023 16:15 #270217
by 2wire078
7I92 Board Fails HM2 Registration was created by 2wire078
I don't have a good understanding of LinuxCNC and I'm running into this error. I sent my CNC plasma table out to be serviced and they refreshed some things because the system was 7 years old. I hooked it all up and everything seems to be fine until I boot up CommandCNC. I get this error every time I try to. I tried digesting it the best I could but I couldn't make much sense of it. I'd really appreciate any insight anyone might have!
Print File:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.15~ccc2.3
Machine configuration directory is '/home/plasma/linuxcnc/configs/EBOB/EBOB_G5_No_Super_Z'
Machine configuration file is 'G5_NO_SUPER_Z.ini'
INIFILE=/home/plasma/linuxcnc/configs/EBOB/EBOB_G5_No_Super_Z/G5_NO_SUPER_Z.ini
PARAMETER_FILE=G5_NO_SUPER_Z.var
TASK=milltask
HALUI=halui2
DISPLAY=gscreen -c commandcnc
Starting LinuxCNC...
Starting HAL User Interface program: halui2
Found file(REL): ./G5_NO_SUPER_Z.tcl
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:13:01:82
hm2_eth: discovered 7I92
board fails HM2 registration
hm2: unloading
Debug File:
Note: Using POSIX non-realtime
hm2/hm2_7i92.0: config.num_stepgens=9, but only 6 are available, not loading driver
hm2/hm2_7i92.0: failed to parse Module Descriptor 3
hm2_eth: rtapi_app_main: Invalid argument (-22)
waitpid failed /usr/bin/rtapi_app hm2_eth
/usr/bin/rtapi_app exited without becoming ready
insmod for hm2_eth failed, returned -1
while executing
"hal loadrt hm2_eth board_ip=\"10.10.10.10\" {config="num_encoders=0 num_pwmgens=0 num_stepgens=9"}"
("eval" body line 1)
invoked from within
"eval hal loadrt $args"
(procedure "loadrt" line 1)
invoked from within
"loadrt $::HOSTMOT2(DRIVER) board_ip=[lindex $::HOSTMOT2(IPADDR) 0] config=[lindex $::HOSTMOT2(CONFIG) 0]"
(file "./G5_NO_SUPER_Z.tcl" line 38)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
2081
Stopping realtime threads
Unloading hal components
Print File:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
TASK=milltask
HALUI=halui2
hm2: unloading
Debug File:
while executing
invoked from within
invoked from within
invoked from within
"source $filename"
invoked from within
2081
- besriworld
- Thank you received: 91
29 Apr 2023 16:40 #270219
by besriworld
Replied by besriworld on topic 7I92 Board Fails HM2 Registration
For the first time, change to the hal file
num_stepgens=6
num_stepgens=6
The following user(s) said Thank You: Muftijaja, 2wire078
- Thank you received: 7462
29 Apr 2023 23:14 #270260
Replied by tommylight on topic 7I92 Board Fails HM2 Registration
And this means you are using the wrong non real time kernel, so after you edit the number of stepgens, see if you have an RT kernel installed, otherwise Mesa 7i92 will not work.Note: Using POSIX non-realtime
The following user(s) said Thank You: 2wire078
