- Thank you received: 7
7I37 installation
3 years 6 months ago #270223
by chili023
7I37 installation was created by chili023
I have a system running with an 7I96 and want to have additional I/O from the 7I37.
I have the 7I37 with 8 outputs and 16 inputs.
The board is connected with 5V from P1 and the Jumper is in the lower position.
I have 24V in out0- and a relay on out0+.
The Relay is always on, so 24V are supplied to the relay.
This doesn't change if the board is powered or not.
The state of the mosfet doesn't change if i supply GND or 5V to the anything IO Pin 33 (Pin corresponded to OUT0).
If I measure all the pins 1-47 vs GND (only odd ons) they have 3.28V.
Any Hint would be appreciated.
Andreas
Andreas
3 years 6 months ago #270228
Replied by PCW on topic 7I37 installation
if you connected 7I37 OUT0- to +24V, you have the MOSFET output polarity
backwards so it will appear to be stuck on
(because of the inherent source drain diode in the the MOSFET)
The following user(s) said Thank You: chili023
Time to create page: 0.126 seconds
