- Thank you received: 2177
Seeing values of gcode settings
3 years 5 months ago - 3 years 5 months ago #271521
Replied by Aciera on topic Seeing values of gcode settings
The magic comment does not work.
'Nested comment found'
It seems that it does not like nested brackets in a comment.
Last edit: 3 years 5 months ago by Aciera.
3 years 5 months ago #271525
Replied by andypugh on topic Seeing values of gcode settings
It seems to be
(py, python code)
or
;py, python code
It calls code here:
github.com/LinuxCNC/linuxcnc/blob/2.8/sr...python_plugin.cc#L67
And multi-line python code can (probably) be passed using "\n"L www.programiz.com/python-programming/methods/built-in/exec
Though if the OP wants to do this a lot, a custom M-code might be easier.
(py, python code)
or
;py, python code
It calls code here:
3 years 5 months ago #271526
by phillc54
Replied by phillc54 on topic Seeing values of gcode settings
If LinuxCNC is started in a terminal the MDI python method does write to terminal but requires a few commands:
I don't know how to get it to appear in AXIS and I have not tried any other GUI's. I did attempt sending it to stderr but that didn't help.
;py,import linuxcnc
;py,s=linuxcnc.stat()
;py,s.poll()
;py,print(s.settings[3])
;py,sys.stderr.write(f"{s.settings[3]}\n")
3 years 5 months ago - 3 years 5 months ago #271529
Thanks phil,
For output to axis add:
;py,import emccanon
;py,emccanon.MESSAGE(str(s.settings[3]))
Last edit: 3 years 5 months ago by Aciera. Reason: use MESSAGE instead of CANON_ERROR
3 years 5 months ago #271530
looks like we can also pass more than one command in a single line:
;py,emccanon.MESSAGE(str(s.settings[2])),emccanon.MESSAGE(str(s.settings[3]))
3 years 5 months ago #271531
by phillc54
MESSAGE is nice...
It even takes f strings:
;py,emccanon.MESSAGE(f"G64 P{str(s.settings[3])} Q{str(s.settings[4])}")
Time to create page: 0.059 seconds
