Ethercat IO Module
04 May 2023 12:28 #270637 by akg1904
Ethercat IO Module was created by akg1904
I have Deiwu Ethercat IO module with 16input and 16 output, as far as I remember I think Rodw also is using same IO module,
if possible can anyone tell me if I can extend the number of inputs and outputs in above mentioned IO module.
Regards
Abhishek
04 May 2023 17:32 #270653 by rodw
Replied by rodw on topic Ethercat IO Module
Deiwu is one of the two Chinese units I've played with. I have a xml file in my repo.
If your want expansion, buy another one. (Or buy Beckhoff hardware)
The following user(s) said Thank You: akg1904
05 May 2023 07:43 #270709 by akg1904
Replied by akg1904 on topic Ethercat IO Module
Hi Rodw,
You've been very helpful. Thank you so much.
So I went though your repo and found the xml file you were talking about, but I couldn't find the xml or name of the other Chinese Ethercat IO module. Could you please tell me the name of the Manufacturer or the  model number?
Also I saw the cost of the Beckhoff and Deiwu modules and the Deiwu is significantly cheaper so I think I will go with it but its also not all that cheap as well.
Do you know if it's possible to add a Breakout Board(BOB) or something similar to Deiwu Ethercat IO module?
If possible can you please give me some hint on how we can achieve the same.
Thanks and Regards
Abhishek
05 May 2023 08:03 - 05 May 2023 08:20 #270710 by rodw
The other I/O board comes from Rtelligent. I also use their drives. It has good documentation and can also do PWM.
www.rtelligent.cn/EtherCAT-Expansion.html
YOu should find it on aliexpress
The other one which also has a few extra features including encoder input is this one but I have not tried it.
www.aliexpress.com/item/1005004377766525.html
 You don't need a BOB, just use the inputs and outputs
Last edit: 05 May 2023 08:20 by rodw.
