switching to linuxcnc from grbl
3 years 5 months ago #270898 by testriderchuck
fairly noob here, some schooling in CNC with MasterCAM9. I've now got a ProVer4030 with grbl. very interested in abandoning Winblows. So far, the only objection with Grblcontrol is that it seems to forget where it's at after waiting a while between runs. Seems I need to rehome after each program run or the new X0Y0Z0 ends up being wherever the machine stopped at.
Does linuxcnc do this too? or is it a function the the program not returning the machine to part x0y0z0?  light bulb that, I'll hafta check that out later.
3 years 5 months ago #270905 by Aciera
No, that is definitely not something that should happen in any CNC controller.
3 years 5 months ago #270988 by Henry Mateo
No, this is not a problem with LinuxCNC. It's made to know where the machine is and put it back there before starting a new program.
You can also set it to go back home before each run of the app.
Time to create page: 0.045 seconds
