Anti-stall spindle
- frogandspanner
08 May 2023 22:01 #270962
by frogandspanner
Anti-stall spindle was created by frogandspanner
I am in the process of linuxCNCing my Chinese 9x20 lathe (bought 27 years ago for the rebuild of by 1966 Norton 650SS).
Z is now working, with homebrew USB HID inputs and a jog wheel and slew/traverse switch to provide a reasonable MMI.
I replaced the AC spindle motor with a DC version so I could simply (and cheaply) control the spindle speed. This involved stripping out the gearing and (I subsequently discovered) the spindle anti-stall clutch.
I wondered if there was a module for linuxCNC that could detect spindle stall so power could then be shut off.
- Thank you received: 5330
09 May 2023 00:28 #270974
Replied by PCW on topic Anti-stall spindle
It could be cobbled together from the spindle speed
(from the spindle encoder), and the near component
(basically similar to whats done to generate spindle-at-speed)
Time to create page: 0.116 seconds
