Set static IP address for mesa 7i96s
- bellda101
16 May 2023 03:35 #271435
by bellda101
Set static IP address for mesa 7i96s was created by bellda101
Hi.
I have a Mesa 7i96s and I need to set a static IP address to 10.10.10.100
I can't seem to find any clear instructions on how to do it
I am using Linuxcnc 2.8.2
I am learning Linux, but I have a long way to go. any help would be appreciated. Thanks
- Thank you received: 4150
16 May 2023 04:52 #271438
Replied by rodw on topic Set static IP address for mesa 7i96s
Step 24-28 here.
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
- JPL
- Thank you received: 118
16 May 2023 05:04 #271439
by JPL
If you don't already have geany installed, (Which will throw an error on the first line of step #25)
Replied by JPL on topic Set static IP address for mesa 7i96s
Also do step #17 before that : sudo apt install geany (the grub-customizer portion of that line is not needed for that)Step 24-28 here.
16 May 2023 05:34 #271442
Actually, After this post, I was worried I missed a step so I went back and watche dmy own video which covers this pretty well!
- xlordofpainx
- Thank you received: 7
02 May 2025 18:26 #327522
by xlordofpainx
Replied by xlordofpainx on topic Set static IP address for mesa 7i96s
i get command not found on many of the commands from the text tutorial
02 May 2025 21:32 #327556
Most of them are installed on our ISOs and IMGs on the downloads page. If you use another install method, you need to install them.i get command not found on many of the commands from the text tutorial
The following user(s) said Thank You: xlordofpainx
Time to create page: 0.124 seconds
