Taper removal in g code lathe.
- jarcysgru
- Thank you received: 6
17 May 2023 17:19 - 17 May 2023 18:14 #271548
by jarcysgru
Taper removal in g code lathe. was created by jarcysgru
Czy jest jakiś sposób w gcode na dostosowanie, wyrównanie stożka w tokarce, aby go nie było?
We are talking about gcode with rays.
G01 Z0.000
Z-17.000
G02 X4.000 Z-18.500 I2.000 K-1.500
G01 Z-30.500
G02 X6.718 Z-33.927 I5.000 K0.000
G01 X12.536 Z-36.836
G03 X14.000 Z-38.603 I-1.768 K-1.768
G01 Z-39.000
Z -39.5
G00 X30.000
Z0.500
G01 Z0.000
Z-17.000
G01 Z-30.500
G01 Z-39.000
Z -39.5
G00 X30.000
Z0.500
Last edit: 17 May 2023 18:14 by jarcysgru.
- Thank you received: 2163
18 May 2023 07:21 #271595
Replied by Aciera on topic Taper removal in g code lathe.
As far as I'm aware we can only rotate by 'R' around the Z axis using
G10 L2 P- <axes R->
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g10-l2
To compensate for chuck misalignment on a lathe you would want to rotate around the Y axis.
However, this can be done using custom kinematics but that is quite a bit more involved.
G10 L2 P- <axes R->
Time to create page: 0.505 seconds
