Python Interface SPINDLE_FORWARD - rpm ignored
- fletch
- Thank you received: 72
22 May 2023 18:33 #271955
by fletch
Python Interface SPINDLE_FORWARD - rpm ignored was created by fletch
I'm on a vanilla v2.8.4 heavily using the Python Interface for the Manualmatic Pendant and all works pretty much as expected, except.. every so often when calling this command:
the rpm specified is ignored and substituted with the one from gmoccpy. This occurs every 5-10 starts, with (it would seem) no particular pattern. I can change the specified rpm, leave it the same, start/stop the spindle frequently, infrequently or sporadically and the result is the same: the specified rpm is ignored.
Am I missing a 'reset' or some such command (I am setting the spindle override to 1 first) that will prevent this?
I've posted this in 'General' but please move to a more appropriate category if required.
self.lc.spindle(self.linuxcnc.SPINDLE_FORWARD, rpm, 0)the rpm specified is ignored and substituted with the one from gmoccpy. This occurs every 5-10 starts, with (it would seem) no particular pattern. I can change the specified rpm, leave it the same, start/stop the spindle frequently, infrequently or sporadically and the result is the same: the specified rpm is ignored.
- Thank you received: 2178
23 May 2023 02:41 #271991
Replied by cmorley on topic Python Interface SPINDLE_FORWARD - rpm ignored
Sounds like gmoccapy might be overriding your commands sometimes.
undoubtedly a race condition.
Hard to say for sure without digging in deep to gmoccapy code.
- fletch
23 May 2023 08:16 #272008
by fletch
Replied by fletch on topic Python Interface SPINDLE_FORWARD - rpm ignored
Thank you for your reply Chris - I was afraid you'd (also) say that.
I'm not sure why gmoccapy would issue a spindle control command without *any* interaction with the gmoccapy interface - it is a little concerning that it would/could do so.
This feels like it is worthy of a bug report?
24 May 2023 01:18 #272064
Well I'm really guessing based on your comment that it uses Gmoccapy's spindle speed - I'm not sure how you confirmed that.
- fletch
25 May 2023 12:06 #272146
by fletch
My 'logic' was based on the spindle starting at the same RPM as specified in gmoccapy's prefs file (via the Settings->Hardware->Starting RPM option) - the DEFAULT_SPINDLE_SPEED is not present in my ini file (as it s in the sims).
I will try to write a Python script to replicate the issue. In the mean time, I just shouted at it:
Not going to pretend I'm happy using the sleep() but it's better than the spindle spinning too fast for the edge finder!
if ( self.ls.spindle[0]["direction"] == 0 ):
#Hit it twice or it'll start at gmoccapy default!!!
self.lc.spindle(self.linuxcnc.SPINDLE_FORWARD, float(rpm), 0)
time.sleep(0.12)
self.lc.spindle(self.linuxcnc.SPINDLE_FORWARD, float(rpm), 0)Not going to pretend I'm happy using the sleep() but it's better than the spindle spinning too fast for the edge finder!
Time to create page: 0.175 seconds
