Jig Borer retrofit
- ricks760
29 May 2023 14:38 #272433
by ricks760
Jig Borer retrofit was created by ricks760
I have been given an old jig borer that I want to retrofit Linuxcnc to it. I plan on using AC servo motors on all three axis's and would like to use glass scales as the position sensors. What kind of setup would be suggested?
- Thank you received: 7462
29 May 2023 16:52 #272438
Replied by tommylight on topic Jig Borer retrofit
Not much to suggest since the chip shortage, but Mesa 7i96S and Mesa 7i77 can still be found.
If you can stretch for that, it is the most versatile combo for now, with plenty of IO, 5 step/dir and 6 full +-10V, another spindle, 7 encoders, etc etc.
As for drives, i have no clue, sorry.
- ricks760
07 Jun 2023 23:55 #273129
by ricks760
Replied by ricks760 on topic Jig Borer retrofit
Thank you for your reply. Where can I find information on configuring the ethernet based Mesa Cards? Peter Wallace suggested this forum.
08 Jun 2023 01:23 #273133
- pippin88
- Thank you received: 51
08 Jun 2023 04:39 #273134
by pippin88
Replied by pippin88 on topic Jig Borer retrofit
Or consider ethercat servos with dual closed loop in the servo driver.
E.g. Delta A3 series.
The linear scale attaches to the servo drive.
Time to create page: 1.290 seconds
