Plasmac THC
02 Jun 2023 22:04 #272770 by Defab
Replied by Defab on topic Plasmac THC
Well that's embarrassing... Yep the connector vibrated out on the jiffy box. Sorry for wasting your time. Youd think as a mechanic I'd look for the obvious things first like I do with cars... lol, live and learn. Now to sort this thc and start cutting. Thanks again guys.
02 Jun 2023 23:09 #272779 by Defab
So I have made those changes and still nothing. I have attached a video to show. Any other ideas? Can I set the gcode speed in sheetcam??
youtube.com/shorts/ULrrrArPyKw
  • Moderator
  • Moderator
03 Jun 2023 00:50 #272786 by tommylight
Replied by tommylight on topic Plasmac THC
Settings page, most of the stuff is at default, so nothing works.
Voltage scale and voltage offset must be set, there is a calculator somewhere...
Did at any point in time the LinuxCNC start with a disabled/powered off/disconnected Mesa board?
I recall that causing the preferences file to mess up and return to defaults, check the config folder, might have a pref file with .back at the end so you can copy and paste stuff to the existing pref file.
On topic, do you have a backup of your config on a USB somewhere?
Please do make some copies and put them in a safe place, any hiccup with the hard drive will render the machine useless and requires a lot of time to set up again.
03 Jun 2023 01:12 #272789 by Defab
Might have started up linux cnc with the table off before.. I assume that would be without the mesa board. I will back up the config. I'll have a look at the config folder. I will back up the config file also.
03 Jun 2023 01:23 #272790 by Defab
Cant find any .Bak files that are older than the new backups I have done. I guess I'll have to start from scratch.
03 Jun 2023 03:13 #272791 by rodw
Replied by rodw on topic Plasmac THC
I don't think there is anything wrong with your config that requires rebuilding from scratch. That will be painful!
What thickness and type is the material?
What is the cutting speed in the gcode?
I don't understand why you are overriding it by 150% I never did that.
​​​​​​What is the torch voltage on screen when cutting.
Perhaps the THC has been disabled in the gcode.
Please share a cut file..
03 Jun 2023 03:20 #272792 by rodw
From the plasmac docs, are any of these gcodes in the file?
G-code THCTHC may be disabled and enabled directly from G-code, provided the THC is not disabled in the THC Section of the  MAIN Tab , by setting or resetting the motion.digital-out-02 pin with the M-Codes M62-M65:
  • M62 P2
     will disable THC (Synchronized with Motion)
  • M63 P2
     will enable THC (Synchronized with Motion)
  • M64 P2
     will disable THC (Immediately)
  • M65 P2
     will enable THC (Immediately
03 Jun 2023 06:21 #272795 by Defab
It's on every material.. I have never seen the torch move while cutting. Trying to cut 1.2mm zincanneal mild steel or 2mm aluminum.
03 Jun 2023 06:22 - 03 Jun 2023 06:25 #272796 by Defab
g code attached
sorry the g code is the tap file right? it wont let me attach it.
Last edit: 03 Jun 2023 06:25 by Defab. Reason: file did not attatch
03 Jun 2023 06:47 #272797 by phillc54
Replied by phillc54 on topic Plasmac THC
Can you post the file created from the BACKUP CONFIG button in the SETTINGS tab.
Time to create page: 0.435 seconds
