Why does linuxcnc limit max feed rate?
12 Jun 2023 15:42 #273399 by Routerworks
Why does linuxcnc limit max feed rate? was created by Routerworks
I have two steppers with exactly the same parameters set up in Stepwizard.  One for the X axis and the other for the Z axis.  Identical settings on the drivers although different.  1280 microsteps per motor step and same parameters in stepwizard .  when jogging the X axis will hit 150 ipm while the Z axis will only to to 50 ipm.  these are open loop with no feedback.  The Z axis is a Swiss motor Nema 32, the X axis is a Stepperonline nema 23.  For general information the Stepperonline nema 23 with a DM556 driver is the smoothest set up I have seen.  Runs quiet and smooth.
Just curious as to what is going on.  I'm ok with the Z axis as is as I don't run my programs too fast.  Or I could replace the motor if I need to.
Regards
12 Jun 2023 17:45 #273409 by smc.collins
Replied by smc.collins on topic Why does linuxcnc limit max feed rate?
post your ini file
12 Jun 2023 20:51 #273416 by Routerworks
Replied by Routerworks on topic Why does linuxcnc limit max feed rate?
File Name: My_New_Mill.ini
File Size:2 KB
12 Jun 2023 22:17 #273425 by PCW
Replied by PCW on topic Why does linuxcnc limit max feed rate?
Your joint and axis MAX_VELOCITY setting is
0.834856580427 for Joint2/Z Axis
and 1.66971316085 for Joint0,1 and Axis X,Y
12 Jun 2023 22:40 #273428 by tommylight
Replied by tommylight on topic Why does linuxcnc limit max feed rate?
Also Z scale is twice more than for X and Y.
Why do all the values look so random?
12 Jun 2023 23:32 #273435 by Routerworks
Not sure. I'll have to look at the Stepwizard settings again or change the ini file myself. Not sure if it's something I'm doing . I'll check it out and let you know.
Time to create page: 0.103 seconds
