Following errors
3 years 4 months ago #273588 by ALR85
Replied by ALR85 on topic Following errors
Hi Tommy
I'll double check shortly but I'm fairly sure that was the folder... It seems to have loads of .hal and .ini files inside it
3 years 4 months ago #273594 by ALR85
Hi
I've double checked and the folder I zipped was
/home/vmc/linuxcnc/configs
Obviously I don't know much about what the contents of this folder actually do, but it seems to me like there has been a variety of config files used over the machines many years and the folder has filled up? I've tried looking for a setting in gmoccapy to tell it which config to use but I couldn't see one
3 years 4 months ago #273595 by ALR85
Pressing the home button results in absolutely nothing - no movement or error messages.
Jogging the Y and Z axis results in no physical movement but the software briefly thinks it is before throwing a Axis Following erro
Jogging the X axis immediately throws up the error
As far as I can tell there are encoders on the motor
3 years 4 months ago #273599 by tommylight
Replied by tommylight on topic Following errors
Your google drive requires access permissions, to many hoops to get to them, make them publicly available.
Turn the motors by hand and watch the on screen DRO if the axis values change.
The following user(s) said Thank You: ALR85
3 years 4 months ago #273609 by ALR85
Apologies for that, it's now public.
The axis value changes if we spin the motor by hand with the timing belt removed
3 years 4 months ago #273610 by tommylight
Drives are disabled, so check for limit/home/safety/e-stop/etc switches, check power for the sensors and drive enables, fuses for said power supplies...
Time to create page: 0.336 seconds
