Schematics for 7c81
  • Donno
  • Donno's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Jun 2023 17:08 #273546 by Donno
Schematics for 7c81 was created by Donno
Is there any mesa guys willing to share the schematics for the 7c81 ? Pretty Pretty PLEASE
I want to buy three but the lady cam told me they will have to redesign because of part shortage 3-6 months. I have a few Spartan 6 LX9 and want to try build one for my production machine.
14 Jun 2023 20:18 - 14 Jun 2023 21:06 #273550 by PCW
Replied by PCW on topic Schematics for 7c81
Its a bit of a nuisance for me to pdf-ize the 7C81 schematics with all the
mixed sheet sizes, but you can get most of the wiring from the 7c81.ucf file
in the source.
Last edit: 14 Jun 2023 21:06 by PCW. Reason: format better
The following user(s) said Thank You: Donno
  • Donno
  • Premium Member
  • Premium Member
15 Jun 2023 07:14 #273577 by Donno
Replied by Donno on topic Schematics for 7c81
Thanks for the reply. That helped a bit what IC's do you use to interface with RS-422/RS-485 and FGPA ?
15 Jun 2023 16:25 #273627 by PCW
The RS-485 chips are SP491 or equivalent
I think there's a 74LCX04 use to convert
the RX out from the SP491s to 3.3V
and invert the DE signal (though this inversion can also be
done in the firmware)
The port bus switches for 5V compatibility are 74CBT16211Cs
  • Donno
  • Premium Member
  • Premium Member
15 Jun 2023 16:25 #273628 by Donno
How much to post schematics ? I have been researching the whole day and it will take me some time to design this not to mention to edit configs. I found schematics for 7i92 are the 7c81 and 7i92 close to design ? Can I replace the PI5C16211 with SN74HCT245PWR ? Do use Raspberry 4B for RS422/485 or FGPA ?
I would like 2 x Parallel port and 2 x Serial Port/Modbus ports output from the FGPA Cards
  • Donno
  • Premium Member
  • Premium Member
15 Jun 2023 16:35 #273630 by Donno
Schematics for the 2 x Parallel Breakout board designed in EasyEDA if anyone is interested
It seems the real time latency is a problem for me when using 2 x parallel port on PC without FGPA
The following user(s) said Thank You: MrRekt
15 Jun 2023 16:54 #273631 by PCW
Ill try an get to this in the next week or so
  • Donno
  • Premium Member
  • Premium Member
15 Jun 2023 16:59 #273632 by Donno
Thanks Dude ! Once I have the schematics i will try and design PCB and use items that are available.
  • Donno
  • Premium Member
  • Premium Member
21 Jun 2023 07:26 #273982 by Donno
Please don't forget about the Schematics
23 Jun 2023 23:21 #274161 by PCW
File Name: 7c81sch.zip
File Size:143 KB
The following user(s) said Thank You: andypugh
Time to create page: 1.193 seconds
