- LinuxCNC
- General LinuxCNC Questions
- Can linuxCNC be (easily) made to send commands over ethernet to my CNC machine?
- mlw19mlw91
22 Jun 2023 18:08 - 22 Jun 2023 18:10 #274070
by mlw19mlw91
^ correct lol. If that's the case it's not the best "search engine". I mean it basically just scours the internet and pieces together what it finds in a coherent way.
Replied by mlw19mlw91 on topic Can linuxCNC be (easily) made to send commands over ethernet to my CNC machine?
Aciera post=274067 userid=25994
Where did you get this from? Is this the result of some Chat GPT query?
I've never heard of such a 'Remote Machine Interface' feature.
Last edit: 22 Jun 2023 18:10 by mlw19mlw91.
- Thank you received: 2176
22 Jun 2023 18:35 #274077
Replied by Aciera on topic Can linuxCNC be (easily) made to send commands over ethernet to my CNC machine?
You got that right.I mean it basically just scours the internet and pieces together what it finds in a coherent way.
- Thank you received: 7488
22 Jun 2023 18:56 #274079
Replied by tommylight on topic Can linuxCNC be (easily) made to send commands over ethernet to my CNC machine?
From the link above:Does this make it "remote machine interface"?
And yes, internet has become a minefield of bad information, so filtering what is good info is becoming damn near impossible. As an exercise, search for "types of pilot arc for plasma cutting machines" it returns over 28000 wrong answers mostly copy/pasted from the same bad source with different wording, only 2 correct answers for over 10 pages of results, one from Hypertherm and the other from Jim Colt on a forum, Jim worked for Hypertherm.
These methods are all fairly manual, but there’s a more automated way to transfer g-code to your CNC machines that is called “DNC,” which stands for “Distributed Numerical Control.”
The idea is to control what g-code winds up on a group of CNC machines from a central server. A menu can be called up on the DNC software on that machine that causes a particular part program to be sent to a particular machine.
DNC requires connecting every machine back to the DNC Server that’s going to manage that machine. This is traditionally done using RS-232 serial connections, like the cable on the right.-
- Reinhard
- Thank you received: 94
23 Jun 2023 02:53 #274110
by Reinhard
Replied by Reinhard on topic Can linuxCNC be (easily) made to send commands over ethernet to my CNC machine?
I worked out an Ethernet-Gateway for linuxcnc, which already passed first tests.
Status-Updates are broadcasted to a Multicast-Group, which means, that you could have multiple clients synchronized to linuxcnc backend (no matter whether the clients are on the same machine or not). Tests showed, that there's no timing problem compared to clients that are connected by shared memory.
For the Command-Channel I implemented a REST interface, which is secured by Http-Digest Authentification. Command-Interface is in concurrency tests - basic commanding works, but some commands don't work yet.
- LinuxCNC
Time to create page: 0.098 seconds
