- Thank you received: 4153
To make LinuxCNC output raw binary data over Ethernet TCP, you can use the Remote Machine Interface (RMI) feature of LinuxCNC. RMI allows you to exchange data between LinuxCNC and external programs or devices using a TCP/IP connection.Here are the steps to configure LinuxCNC to output raw binary data over Ethernet TCP:
Note that implementing a custom component for raw binary data output requires programming skills in the HAL language. It's recommended to refer to the LinuxCNC documentation and resources for detailed guidance on writing custom components and working with the RMI feature.
- Ensure that you have LinuxCNC installed and running on your machine. Make sure your LinuxCNC configuration and machine setup are properly configured and operational.
- Create a custom component in LinuxCNC's configuration. A component is a module that handles data exchange between LinuxCNC and external programs/devices. You'll need to write a custom component that can handle the raw binary data output.
- Write the custom component using the HAL (Hardware Abstraction Layer) language. HAL allows you to define custom connections, signals, and functions for data exchange within LinuxCNC. In your custom component, you'll define an output signal that represents the raw binary data.
- In your custom component, use the
function to send the raw binary data to the TCP/IP connection. TheCode:netoutfunction allows you to send data to a remote program or device over TCP/IP.Code:netout- Configure the TCP/IP connection settings in your custom component. Set the IP address and port number of the remote program or device that will receive the raw binary data.
- Load and run your custom component within LinuxCNC. You can do this by adding the custom component to your LinuxCNC configuration file or using the LinuxCNC command-line options.
- Start the remote program or device that will receive the raw binary data over TCP/IP. Make sure it is listening on the specified IP address and port number.
- Once both LinuxCNC and the remote program/device are running, LinuxCNC will output the raw binary data over the TCP/IP connection. The remote program/device can then receive and process the data as per your requirements.
Where did you get this from? Is this the result of some Chat GPT query?So I've been told that this is a possibility, but not sure it's necessary or worthwhile:
Aciera post=274067 userid=25994
I've never heard of such a 'Remote Machine Interface' feature.
You got that right.I mean it basically just scours the internet and pieces together what it finds in a coherent way.
