Adding file extensions
28 Oct 2010 15:12 #4938
by beermkr
Adding file extensions was created by beermkr
I use CamBam to generate my g-code and it uses a .nc file extension. Is there a way to add that as a "All Machineable file" extension so I do not have to change it to all files to see them?
R/
Mike
R/
Mike
28 Oct 2010 15:20 #4940
Replied by andypugh on topic Re:Adding file extensions
I think that you can add other file extensions in the INI file, under [FILTER] PROGRAM_EXTENSION
28 Oct 2010 22:47 #4951
by Rick G
Replied by Rick G on topic Re:Adding file extensions
Like Andy said,
from the manual...
or try
PROGRAM_EXTENSION = .ngc, .tap xyz post processor
with the type of extension you use example above is .tap
Rick G
from the manual...
PROGRAM_EXTENSION = .extension Description
If your post processor outputs files in all caps you might want to add the following line:
PROGRAM_EXTENSION = .NGC XYZ Post Processor
or try
Rick G
29 Oct 2010 01:19 #4952
by beermkr
Replied by beermkr on topic Re:Adding file extensions
That did it... I figured that was it but the whole Linux thing is a little new to me and changing stuff wigs me out sometimes!
Thanks for the help!
R/
R/
29 Oct 2010 14:33 #4963
by BigJohnT
Replied by BigJohnT on topic Re:Adding file extensions
It gets easier as you go along...
Time to create page: 0.409 seconds
