Servo driver SG-AS20 YUHAI or CTB
11 Jul 2023 19:43 #275233 by besriworld
Replied by besriworld on topic Servo driver SG-AS20 YUHAI or CTB
Yes, this motor/driver is complete garbage. Today it started making bad noises. Looks like a bad bearing
youtube.com/shorts/onTwy6WiKgk?feature=share
Feedback in linuxcnc does not work for this driver. The acceleration must be very low, otherwise the pid controller compensates the position. Can the PID regulator be set with a long delay? Currently trying with P=1 D=0 and I=0 . I just want linuxcnc to watch for the wrong position.And when I turn of-on the motor, the program will know what position the screw pair
11 Jul 2023 20:24 - 11 Jul 2023 20:27 #275234 by chris@cnc
Replied by chris@cnc on topic Servo driver SG-AS20 YUHAI or CTB
It sounds the PID/gain in the amp is set too hard. is there any software to look and adjust directly on the amp. PID of 1 or 5 in linuxcnc is ok. the servo has his own control loop and should be the master in the control loop. Look for parameters like Control Loop gain and decrease the values. 11 kw is already a large servo that needs to be adjusted well.
edit
next step would be to measure the frequency and compensate with filter
Last edit: 11 Jul 2023 20:27 by chris@cnc.
11 Jul 2023 21:06 #275236 by besriworld
This is a 1kw servo motor. I have two of these. It's not from a bad setup. I already tried with another one. If I have an acceleration greater than 200mm/s, LinuxCNC adjusts and sends more steps. So when the servo motor stops, it turns back several 160-300 steps. This is with a 10mm screw and 2400 RPM
21 Jul 2023 18:57 #275970 by besriworld
I want to add a delay when reading the encoder. In this way, linuxcnc will get the current speed of the motor and will not make a correction with the wrong speed of the PID control. What do you think? How can it be done?
21 Jul 2023 20:02 - 21 Jul 2023 20:05 #275971 by Aciera
Replied by Aciera on topic Servo driver SG-AS20 YUHAI or CTB
Have you considered not closing the loop in linuxcnc at all and just let the driver handle the motor? In my opinion it is futile to try building a PID loop with delayed encoder feedback.
Last edit: 21 Jul 2023 20:05 by Aciera.
21 Jul 2023 20:21 #275973 by tommylight
Replied by tommylight on topic Servo driver SG-AS20 YUHAI or CTB
+1
21 Jul 2023 22:01 #275977 by besriworld
Yes, but I like having a second line of defense against bad wiring or shock issues. The other advantage is that when the motors are turned off (mesa works and LinuxCNC works), LinuxCNC knows the exact coordinates.
21 Jul 2023 22:20 #275979 by tommylight
Maybe LinuxCNC can show actual encoder position and not use it for feedback and PID.
Not sure how exactly as i never used that, but someone here on the forum mentioned it a while back.
22 Jul 2023 13:14 #275992 by besriworld
Ok, but how hard is it to add a delay when reading the encoder? I think this is the best way for me.
Or should I add linear encoders. But for one axis it is a difficult task.
22 Jul 2023 13:37 #275994 by tommylight
Adding delays to real-time, mission-critical, life-threatening, etc stuff is never good.
You can add linear scales, that should work perfectly, also consider adding encoders to ballscrews or with pulleys if using belts.
Use the hal scope and measure what the exact delay is, probably could lover the base period time to half or 1/4 and see if that is still usable.
Just make sure the E-stop works. :)
Time to create page: 0.507 seconds
