Absolute position of joint?
12 Jul 2023 02:59 #275251 by chowderhead
Absolute position of joint? was created by chowderhead
Is there a HAL pin, named or numbered parameter, or other source reporting the absolute machine position, e.g. position relative to home?
12 Jul 2023 05:40 #275255 by JPL
Replied by JPL on topic Absolute position of joint?
Commanded axis position in machine coordinates: halui.axis.L.pos-commanded
Feedback axis position in machine coordinates: halui.axis.L.pos-feedback
Commanded axis position in relative coordinates: halui.axis.L.pos-relative
(replace 'L' with axis name)
More info here: linuxcnc.org/docs/html/man/man1/halui.1.html
Is this what you need?
The following user(s) said Thank You: chowderhead
12 Jul 2023 19:21 #275294 by chowderhead
Replied by chowderhead on topic Absolute position of joint?
Thanks JPL. I think I should have slept before asking that question. I had an issue yesterday that I couldn't figure out - it looked like the halui.axis pin values were changing with G54. Now looking at it this morning, I see they aren't.
Living up to my nom de guerre...
14 Jul 2023 12:54 #275411 by tommylight
Replied by tommylight on topic Absolute position of joint?
Spammer booted.
