pendant
12 Jul 2023 17:52 #275289 by Powerhouse.
pendant was created by Powerhouse.
Hi there can somone pleas point me where do i get a diagram to wire a pendant to a 7i96 and the pocon config
Im using a 100ppr pendant.
13 Jul 2023 14:47 #275345 by grijalvap
Replied by grijalvap on topic pendant
May be you can start with this
store.mesanet.com/index.php?route=produc...d=116&search=pendant
7i96 has limited input output but you can use serial to conect 7i73
13 Jul 2023 15:47 #275353 by PCW
Replied by PCW on topic pendant
Assuming this is a 7I96 and not a 7I96S:
If you have enough free isolated input pins you can use
7i96_inmd.bit which adds MPG encoders to the isolated
inputs. In addition MPG encoders are available on P1
with 7i96_p1inmd.bit
13 Jul 2023 18:08 #275359 by zz912
Replied by zz912 on topic pendant
I used it for inspiration:
wapl.es/cnc/2020/02/23/linuxcnc-jog-wheel-setup.html
But
1) I used break board for conector P1
zz912.webnode.cz/ochrana-p1/
2) I used HAL component encoder (virtual encoder)
It is not manual step by step. Maeby it help you.
If you have enough normal inputs, you dont have to use P1.
13 Jul 2023 18:45 #275366 by beefy
Replied by beefy on topic pendant
As far as a wiring diagram goes, have you studied the 7i96 user manual ?
The encoder inputs on terminal block TB2 are clearly listed. I'm guessing your pendant has 4 wires which would be +5v, GND, A+, B+
If that's the case you'd wire them to pin 12 (+5VP), pin 9 (GND), pin 7 (ENCA+), pin 10 (ENCB+) respectively.
Time to create page: 0.111 seconds
