PNC CONFIG- 7I76 PIN NOT SHOWING
- rajsekhar
- Thank you received: 12
17 Jul 2023 01:54 #275607
by rajsekhar
PNC CONFIG- 7I76 PIN NOT SHOWING was created by rajsekhar
I am using 7i92 7i76 7i84.
All connected as per document.
Now, I am getting error report while starting Linuxcnc. Report attached. Hal and INI attached.
Note: I had started this same set up earlier when all digital input and output was unused. The Z axis was connected and working fine. But no pin for 7i76 and 7i84 was shown in halshow.
Request for solution.
- Thank you received: 5308
17 Jul 2023 02:37 #275609
Replied by PCW on topic PNC CONFIG- 7I76 PIN NOT SHOWING
Do you have field power (Orange connector) applied to both the 7I76 and 7I84?
- rajsekhar
17 Jul 2023 08:52 #275632
by rajsekhar
Replied by rajsekhar on topic PNC CONFIG- 7I76 PIN NOT SHOWING
Yes, filed power connected. Yellow LEDs are glowing.
- rajsekhar
17 Jul 2023 14:10 #275649
by rajsekhar
Well, the problem solved.
Actually I am using separate VIN (12 VDC) and VFIELD (24 VDC).
Now the GND of both VIN and VFIELD should be sorted and connected. But I was using only VFIELD negative.
