tooledit Rounding issue on tool offset
- robh
- Thank you received: 24
17 Jul 2023 20:15 #275679
by robh
tooledit Rounding issue on tool offset was created by robh
Linuxcnc 2.8.4
Metric Mode
Diamiter programing on
Gui Axis
Using Lathe mode on Axis and tooledit as the tool table editor
i have some long tools 200+mm in the X (its a dual turret tool posts on X slide, Z can be long lengths also as machine is quite large 500mm Swing over bed ,
anways
when you edit a tool length of say 300.xxx it starts to round up the numbers when you save the file and do a reload in Axis GUI, the display at bottom shows the round up oddly but id exspect that there, but when you reopen the tooledit editor it has rounded up the values and displays the round up and not the value you just entered into the table, so when you try to edit the tool by the micron value you cant.
the machine is in Metric mode and diamiter programing.
has any one else noticed this? for now i am just editing the table via text editor and saving and reloading in the GUI and problem is no more.
thanks, rob
Metric Mode
Gui Axis
anways
thanks, rob
- Thank you received: 4648
18 Jul 2023 22:02 #275772
Replied by andypugh on topic tooledit Rounding issue on tool offset
How odd. It seems to allow at least 8 decimals for 0.xxxx... but 300.xxx... is rounded to only 3 places.
Can you raise this as a bug here?
github.com/LinuxCNC/linuxcnc/issues
- robh
21 Jul 2023 21:45 #275976
by robh
Replied by robh on topic tooledit Rounding issue on tool offset
have raised a bug report for this issue
github.com/LinuxCNC/linuxcnc/issues/2593
Time to create page: 0.078 seconds
