trying to run remora
- OneMyr
18 Jul 2023 18:23 #275753
by OneMyr
trying to run remora was created by OneMyr
Hello there.
actually i am trying to run Remora on my Rpi4, i am using debian bookworm, but when i try to run remora.xyz, appears this message. someone can help me resolving this?
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/cnc/linuxcnc/configs/remora-xyz'
Machine configuration file is 'remora-xyz.ini'
INIFILE=/home/cnc/linuxcnc/configs/remora-xyz/remora-xyz.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./remora-xyz.hal
Debug file information:
Note: Using POSIX realtime
bcm2835_init: gpio mmap failed: Operation not permitted
rt_bcm2835_init failed. Are you running with root privlages??
remora: rtapi_app_main: Operation not permitted (-1)
./remora-xyz.hal:7: waitpid failed /usr/bin/rtapi_app remora
./remora-xyz.hal:7: /usr/bin/rtapi_app exited without becoming ready
./remora-xyz.hal:7: insmod for remora failed, returned -1
70177
Stopping realtime threads
Unloading hal components
remora: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Tue Jul 18 18:16:16 UTC 2023
UTC Date: Tue Jul 18 18:16:16 UTC 2023
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
70177
remora: not loaded
pastebin.com
The following user(s) said Thank You: cakeslob
- Thank you received: 4138
18 Jul 2023 19:40 #275758
Replied by rodw on topic trying to run remora
This has been fixed in the last day or so.
However, I am not sure that you can upgrade to it without compiling from source as I don't think there is a V2.9 buildbot for the Pi
The following user(s) said Thank You: OneMyr
- OneMyr
20 Jul 2023 11:02 #275886
by OneMyr
Replied by OneMyr on topic trying to run remora
okay... but, how i compile from source? can you help me with?
- meister
- Thank you received: 501
20 Jul 2023 12:00 #275892
by meister
Replied by meister on topic trying to run remora
Time to create page: 0.075 seconds
