I've taken up machining as a retirement hobby and last year acquired a full sized VMC for which I'd like to replace the ailing Semens acramatic controller with LinuxCNC. That VMC uses Yaskawa servo controllers that can take either analog servo inputs, or step/dir inputs. The spindle motor takes an analog 10V signal for speed control. I am under the impression that analog servo control may work a bit better than step/dir, so it seemed that a Mesa 7i97 analog servo controller was a good option.
Mesa cards have been challenging to obtain, and after checking their store site for about 6 months for stock, at the end of May I emailed them to inquire about availability. I was told a new card was coming out to replace the 7i97. I was recently contacted by them and told that the replacement 7i92TM was now available. So I ordered one. After reading a bit, it appears that 7i92TM would need a 7i77 break out board to handle analog servos. The 7i77 is not currently available, so I contacted Mesa sales. They placed the 7i92TM order on hold and have forwarded my email to their tech support, from which I haven't heard back yet.
So, I'm hoping for some help from knowledgeable folk that might suggest if a different approach makes sense, or do I just need to continue holding?
1) How much difference is step/dir vs analog control going to make for servos? Should I consider using step/dir for the 3 basic axises, and work up some other solution for the spindle motor control?
2) Does anyone know what Mesa's roadmap is? There isn't any clear indication on their website of what is going to be replaced, it just shows either out of stock or obsolete/replaced by for many of their cards. It gets a little unclear what is supported by linuxcnc. Obviously I'd prefer not to implement something that is immediately obsolete.
