Synchronize 2 axes in manual mode
- angelnu
- Thank you received: 4
20 Jul 2023 17:55 #275908
by angelnu
Synchronize 2 axes in manual mode was created by angelnu
It is possible to move 2 axes at the same time (synchronized) in manual mode by means of a joystick, the idea is to move the X axis and the A axis to position parts with helix. Enter the pitch of the helix in some text box and with the joystick or a button move the X axis and the A axis according to the pitch of the helix.
- Thank you received: 5308
20 Jul 2023 19:40 #275912
Replied by PCW on topic Synchronize 2 axes in manual mode
Should be possible in hal, basically a custom jogging mode...
The following user(s) said Thank You: angelnu
- zz912
- Thank you received: 98
21 Jul 2023 04:07 #275926
by zz912
Replied by zz912 on topic Synchronize 2 axes in manual mode
I think that one of the ways could be switching the kinematics.
linuxcnc.org/docs/2.9/html/motion/switchkins.html
Normal kinematics:
A = A
Thread kinematics:
A = constant * Z
I am by no means a kinematics specialist.
Normal kinematics:
A = A
Thread kinematics:
A = constant * Z
- angelnu
22 Jul 2023 19:12 #276011
by angelnu
Replied by angelnu on topic Synchronize 2 axes in manual mode
Any example of how to perform a custom jogging mode?
22 Jul 2023 21:11 #276022
Do you have normal joystick jogging set up?
That would be the first step.
Basically you would feed the jog count generated by the joystick component
to both A and Z jog count pins (axis.a.jog-counts and axis.z.jog-counts)
with a predefined jog scale for A and Z (axis.a.jog-scale and axis.z.jog-scale)
You would also have to set axis.a.jog-enable and axis.z.jog-enable
Ultimately you would like need some logic and perhaps multiplexer
components to allow selection of this specific mode while allowing the normal
per axis jog modes to still operate normally
- angelnu
05 Sep 2023 19:49 #280024
by angelnu
I have been very busy all month and I have not been able to resume the issue.
The joystick is connected to:
# --- JOG-X-POS ---
Net Jog-X-Pos <= Hm2_5i25.0.7i76.0.0.input-20
# --- Jog-X-Neg ---
Net Jog-X-Neg <= Hm2_5i25.0.7i76.0.0.input-21
How can I connect the joystick to the axis.x.jog-counts?
In the manual:
axis.l.jog-counts in S32
Connect to The "Counts" Pin of an External Encoder to use Physical Jog Wheel.
# --- JOG-X-POS ---
# --- Jog-X-Neg ---
In the manual:
Time to create page: 0.201 seconds
