Machine Rounding Paths
- Askjerry
- Thank you received: 31
23 Jul 2023 14:38 - 23 Jul 2023 14:42 #276076
by Askjerry
Machine Rounding Paths was created by Askjerry
I have built a bunch of machines and configured even more... but I don't recall having this issue before.If I run the G-Code normally... it is rounding the corners... taking a shortcut. If I run the code in step mode, the cuts are perfect.
I've built a bunch of machines and configured even more... I don't think I ever had this happen before. I'm going to head to the shop to see if I can figure it out. I've attached the HAL and INI files if you have suggestions.
Thanks,
Jerry
Thanks,
Jerry
Last edit: 23 Jul 2023 14:42 by Askjerry.
- Thank you received: 7488
23 Jul 2023 14:47 #276077
Replied by tommylight on topic Machine Rounding Paths
Path Control Mode section
linuxcnc.org/docs/2.9/html/gcode.html
- Askjerry
23 Jul 2023 15:09 #276079
by Askjerry
Replied by Askjerry on topic Machine Rounding Paths
Well... it looks like I owe you at least a cup of coffee Tommylight!
I wonder how that got set differently????
Now I know... I'm updating my POST PROCESSOR for Aspire to include G61 in the header.
For those following this post...
- G61 - Exact path mode, movement exactly as programmed. Moves will slow or stop as needed to reach every programmed point.
-G61.1 - Exact stop mode, movement will stop at the end of each programmed segment.
- G64 P0.015 (set path following to be within 0.015 of the actual path) This actually does much more, you would need to read the section.
Thanks for a QUICK FIX... I thought I was going to be in the shop for hours figuring it out!!!
The following user(s) said Thank You: tommylight, besriworld
23 Jul 2023 15:46 #276082
You can also add that to the ini file, it saves the trouble of entering that in MDI if you stop a running program and continue with "run from here". Here is a snippet from one of my configs
[RS274NGC]
RS274NGC_STARTUP_CODE = G21 G40 G90 G94 G97 G64 P0.025
Adjust to your requirements, this is for a metric machine.
[RS274NGC]
The following user(s) said Thank You: Askjerry, besriworld, Mr. Mass
- Askjerry
24 Jul 2023 12:07 #276147
by Askjerry
That is useful... I didn't know you could specify things like that in the INI file.
I'll do that, I also run a Metric machine... my YouTube videos go worldwide... and more people use metric than not. Besides... I like the system better anyway.
THANKS!
THANKS!
Time to create page: 0.152 seconds
