linuxcnc general features
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
27 Jul 2023 12:50 #276373 by tommylight
linuxcnc general features was created by tommylight
General features are on the main LinuxCNC page, it can control a wide range of machines, from very simple to very, very complicated machines with 9 axis and each of those axis can have more than one joint/drive/motor, up to 8 i think, and any number of iputs and outputs, digital and analog, encoders, resolvers, glass scales, ethercat stuff, modbus, has it's own PLC named Clasic Ladder, has logic stuff like AND/OR/NAND/XOR/INV etc etc.
How many MHz does what run?
Mesa boards can output up to 10MHz pulses on each output at the same time, can count nearly as much pulses on inputs. Field inputs and outputs can do 1 KHz but can be pushed to 4 or more.
Read ahead can be set to 1 or 50 i think, not sure, but pretty sure the latest versions will read everything before the machine starts moving. You might want to double check this.
27 Jul 2023 18:28 #276391 by beefy
Replied by beefy on topic linuxcnc general features
hi i am using linuxcnc and i have mesa 7i76e board. Where can I find Linuxcnc general features? How many MHz does it run at? How many lines of code does it have read-ahead capability?
Heaps of information starting here:
linuxcnc.org/docs/
  • Moderator
  • Moderator
28 Jul 2023 11:52 #276452 by tommylight
Replied by tommylight on topic linuxcnc general features
You are welcomed, always.
