- LinuxCNC
- General LinuxCNC Questions
- Lantek compatibility with QtPlasmac or Other LinuxCNC Interface?
- santy
- Thank you received: 10
28 Jul 2023 10:21 #276450
by santy
Lantek compatibility with QtPlasmac or Other LinuxCNC Interface? was created by santy
Hello. A fellow friend of mine uses Lantek for his machines, which doesn't come in very handy with linuxcnc itself for a retrofitted plasma machine.
For example, the generated machine code looks like:
And surely linuxcnc doesn't read this.
What procedure can i follow to allow lantek to work with qtplasmac?
I'm thinking maybe i can change the M codes somehow in the post processor for lantek, to M3 to turn on the torch probe + on sequence, but i still need to imprint 'material number' in the beginning and some other start parameters.
do you guys have any suggestions?
%1806
(JOB000476)
G71
N3 G90 D1 T1
N5 G00 X22.5 Y-1186.4
N7 M21
N9 G41
N11 G01 X17.61 Y-1189.88
N13 G03 X26.745 Y-1182.155 I22.5 J-1186.4
N15 G03 X19.02 Y-1191.29 I22.5 J-1186.4
N17 G01 X22.5 Y-1186.4
N19 G40
N21 M20
N23 G00 X22.5 Y-998.9
N25 M21
N27 G41
N29 G01 X17.61 Y-1002.38
N31 G03 X26.745 Y-994.655 I22.5 J-998.9
N33 G03 X19.02 Y-1003.79 I22.5 J-998.9
N35 G01 X22.5 Y-998.9
N37 G40
N39 M20
N41 G00 X215.535 Y-945.15
N43 M21
N45 G41
N47 G01 X210.645 Y-948.63
N49 G03 X219.775 Y-940.905 I215.535 J-945.15
N51 G03 X212.05 Y-950.04 I215.535 J-945.15
N53 G01 X215.535 Y-945.15
N55 G40
N57 M20
N59 G00 X215.535 Y-1107.65
N61 M21
N63 G41
N65 G01 X210.645 Y-1111.13
N67 G03 X219.775 Y-1103.405 I215.535 J-1107.65
N69 G03 X212.05 Y-1112.54 I215.535 J-1107.65
N71 G01 X215.535 Y-1107.65
N73 G40
N75 M20
N77 G00 X315.71 Y-795.69And surely linuxcnc doesn't read this.
- Thank you received: 4138
28 Jul 2023 12:36 #276456
Replied by rodw on topic Lantek compatibility with QtPlasmac or Other LinuxCNC Interface?
Why not ask lantek to produce a post processor for QTplasmac?
- RDA
- Thank you received: 43
03 Aug 2023 09:32 #276829
by RDA
Replied by RDA on topic Lantek compatibility with QtPlasmac or Other LinuxCNC Interface?
My guess is money, Lantek will ask an arm and a leg to make a new post processor. I have seen quotes ranging between 5-10k$ for a post processor.
03 Aug 2023 19:24 - 03 Aug 2023 19:25 #276843
But QTplasmac already uses this technique so you would need to modify the existing QTplasmac filter.
It would be cool to be able to interface with high end nesting programs. Maybe the QTplasmac guys could develop an interface that allows extending the filter. Maybe ask in the plasmac section.
Then write a filter so that linuxcnc modifies the Gcode file when it opens.My guess is money, Lantek will ask an arm and a leg to make a new post processor. I have seen quotes ranging between 5-10k$ for a post processor.
Last edit: 03 Aug 2023 19:25 by rodw.
- LinuxCNC
Time to create page: 0.101 seconds
