root user
- foam man
- Thank you received: 5
07 Aug 2023 02:44 #277186
by foam man
root user was created by foam man
hi
i have not used my linux computer for a while, and tonight when i tried to start it up i got a root aaccount is locked errorr. code 4
its asking for a root user #
i have tried restarting but it went back to the excact same thing
i have less then no idea what this means, and any help is appreciated
thanks
thanks
- Thank you received: 7468
07 Aug 2023 10:56 #277219
Replied by tommylight on topic root user
Might have better luck asking this on Debian forums as this is Linux issue.
Personally, never ever had this happen, in over 20 years and at least 15 PC running Linux at any given time, so i have no idea what would cause it, except maybe a failling hard drive and messed file system permissions.
- Thank you received: 426
07 Aug 2023 11:07 #277221
Replied by Cant do this anymore bye all on topic root user
You didn't accidentally start in recovery mode ?
07 Aug 2023 11:52 #277229
One more thing, check the BIOS date and time, that might also cause this if the battery is low.
- foam man
08 Aug 2023 15:58 #277329
by foam man
Replied by foam man on topic root user
after it didn't work I ctrl d it and tried recovery mode but it did the same thing.
can you elaborate a little more on checking the date and time and battery low thing
thanks
thanks
- alishakihn
- Visitor
15 Aug 2023 03:24 - 15 Aug 2023 10:30 #278025
by alishakihn
Replied by alishakihn on topic root user
If you're encountering a "root account is locked" error on your Linux computer, it means that the root user account has been locked or disabled. This usually happens for security reasons or when there have been multiple unsuccessful login attempts.
To resolve this issue, you can try the following steps:
1. Restart your computer and access the GRUB boot menu. You can usually do this by pressing the Shift key or Esc key during the boot process. If you have a dual-boot setup, you may need to choose the appropriate option for your Linux distribution.
2. In the GRUB boot menu, select the recovery mode or rescue mode option. This will boot your computer into a root shell or a minimal environment.
3. Once you're in the root shell, you can try unlocking the root account by running the following command:
passwd -u root
This command will unlock the root account and allow you to set a new password for it.
4. After running the command, you can reboot your computer and try logging in as the root user with the new password.
If the above steps don't work or if you encounter any other issues, it's recommended to seek assistance from a more experienced Linux user or consult the documentation and support resources specific to
passwd -u root
Last edit: 15 Aug 2023 10:30 by tommylight. Reason: Link removed
15 Aug 2023 10:32 - 15 Aug 2023 10:41 #278038
Removed link from above post.
@alishakihn,
You spam again, you get banned.
Edit
He spamed on other topics with different user name, so he got banned.
@alishakihn,
Edit
Last edit: 15 Aug 2023 10:41 by tommylight. Reason: more info
Time to create page: 0.096 seconds
