Press Brake controls
- cutnweld
- Thank you received: 3
07 Aug 2023 18:06 #277261
by cutnweld
Press Brake controls was created by cutnweld
Hello all, new to the forum. I am wondering if there is any pressbrake user interfaces out there? I have a Durma brake with Y1 and Y2 cylinders on the ram with a linear encoder each side along with an X and R backgauge. Has anyone ever retrofitted a machine like this with Linux? If not would it be possible to do? The servos and drivers are there, The solenoids and relays are there along with the scales, I do not like the old Cybelec control however, and do not have 25k to throw at a control upgrade.
- Thank you received: 2177
07 Aug 2023 18:30 #277264
Replied by Aciera on topic Press Brake controls
There have been a few (here are two threads that might get you started):
forum.linuxcnc.org/show-your-stuff/45716...face-and-comp#241297
forum.linuxcnc.org/30-cnc-machines/42100...up-questions?start=0
- vre
- Thank you received: 17
11 Dec 2025 19:12 #339982
by vre
Replied by vre on topic Press Brake controls
I have a similar machine but also has Z1-Z2 for backgauges.
Something new about some gui that fits to these types of machines ?
- chrispriceab
06 Jan 2026 02:41 #341040
by chrispriceab
Replied by chrispriceab on topic Press Brake controls
Looking to join a thread on this topic and collaborate. Is there any progress on a Brake Press UI and a repo or something where I can use/contribute.
I'd prefer not to use a glade UI due to deprecation if possible.
- Thank you received: 7498
06 Jan 2026 03:15 #341041
Replied by tommylight on topic Press Brake controls
Have a look at FlexGUI, seems easy to make and GUI you like/need/want
forum.linuxcnc.org/flex-gui/57726-flex-gui
The following user(s) said Thank You: NWE
- NWE
- Thank you received: 84
15 Jan 2026 02:11 #341401
by NWE
Replied by NWE on topic Press Brake controls
I'm working on a press brake retrofit and will also soon be needing a gui for it. I originally planned to do it in glade, but have been looking at FlexGUI and am open to the idea of using that or similar instead. What do you say, we start a thread and get it rolling?Looking to join a thread on this topic and collaborate. Is there any progress on a Brake Press UI and a repo or something where I can use/contribute.
Time to create page: 0.177 seconds
