Mesa CT
08 Aug 2023 16:07 #277331 by Doug Crews
Mesa CT was created by Doug Crews
Hello,  This is most likely a question for JT.  I installed mesa Configuration Tool 2   using gdebi  it reported one failed dependency, something to do with archives I think.   I then noticed the CNC was missing from the start menu, so I did a reboot.   Now  I’m getting the “oh no! something has gone wrong and the system can’t recover” dialog after I enter login credentials.  I’m running an RPI 4    and have…had…Linuxcnc ver 2.9 installed. I'm sure…”Pretty Sure”  what I ran was   wget github.com/jethornton/mesact/releases/do...t_2.0.0_armhf.debI’m wondering if I’m look at having to do total wipe / clean sweep / reformat..?-Doug
18 Aug 2023 12:12 #278361 by JT
Replied by JT on topic Mesa CT
Tom L on the IRC builds the Rpi debs for me and if you used gdebi to install if there is a missing dependency I don't think gdebi will install anything.
JT
28 Dec 2023 09:34 #289236 by flyingbrick
Replied by flyingbrick on topic Mesa CT
Hi John, how come the 64bit versions are missing :-(
Time to create page: 0.287 seconds
