mesa card stock, generla questions
09 Aug 2023 09:34 - 09 Aug 2023 09:37 #277412 by BeansAndBrass
mesa card stock, generla questions was created by BeansAndBrass
i have an bridgeport interact 300 mill that i bought for a steal, it came with a new unidrive pre installed, now i would like to get the 7i76e board, my question is would that be the best option (performance) or should i look at somting diffrend
and if it is the best option dous anyone have an idea wen there back in stock?
greetings from belguim!!!
Last edit: 09 Aug 2023 09:37 by BeansAndBrass.
09 Aug 2023 12:37 #277429 by tommylight
Replied by tommylight on topic mesa card stock, generla questions
Mesa 7i76E is pretty hard to find, but 7i96S was in stock at www.welectron.com in Germany, and by now maybe www.eusurplus.com in Portugal might have them.
If you need more IO, a 7i84 is easy to wire and adds 32 inputs and 16 outputs.
11 Aug 2023 14:29 #277642 by BeansAndBrass
Replied by BeansAndBrass on topic mesa card stock, generla questions
is there also a way for analog spindel output to be added?
11 Aug 2023 15:06 #277645 by PCW
Replied by PCW on topic mesa card stock, generla questions
The 7I96S has analog spindle output
  • salmawisoky
  • salmawisoky's Avatar
  • Visitor
  • Visitor
15 Aug 2023 10:05 - 15 Aug 2023 10:47 #278035 by salmawisoky
Replied by salmawisoky on topic mesa card stock, generla questions
The 7i76e board is a popular choice for retrofitting CNC machines like the Bridgeport Interact 300 mill. It offers good performance and compatibility with LinuxCNC, making it a viable option for upgrading your machine.
Regarding stock availability, I don't have real-time information on the availability of specific products. The best way to determine when the 7i76e board will be back in stock is to check with the official suppliers or distributors of the board. They will have the most up-to-date information on inventory and availability. You can visit the official website of the manufacturer or contact them directly to inquire about the stock status and estimated restocking dates.
Alternatively, you can also explore other CNC control board options that are compatible with your machine and meet your performance requirements. Researching and comparing different boards, reading user reviews, and seeking recommendations from CNC machining communities or forums can help you identify alternative options that may be available and suitable for your needs.
When selecting a CNC control board, consider factors such as compatibility with your machine, performance capabilities, support for your desired software (such as LinuxCNC), expandability options, and the availability of technical support or documentation.
Remember to carefully review the specifications, features, and compatibility of any CNC control board you consider before making a purchase to ensure it meets your specific requirements and is compatible with your machine.
Last edit: 15 Aug 2023 10:47 by tommylight. Reason: embeded links removed
15 Aug 2023 10:49 #278040 by tommylight
Removed link from above post, spammer banned, 3 user names embeding links.
Time to create page: 0.529 seconds
