What is the "proper" zero origin
12 Aug 2023 12:10 #277724 by rodw
Replied by rodw on topic What is the "proper" zero origin
Blazini is talking about a moving table mill, Rod about a moving head mill!
So both are right. :)
BTW, TLDNR
I'm not sure about that. I was really taking about both as they have the same geometry. On my manual mill, I was only ever interested in the movement of the tool in relation to the workpiece as I cranked the DRO to get to a position on a drawing using Cartesian coordinates. That's how I think. Thats how the preview in Linuxcnc is. The movement of the table is just a distraction, a byproduct if you will.
and I was not arguing, I just stated my thoughts, my theory as I stated..
12 Aug 2023 13:58 - 12 Aug 2023 18:54 #277729 by Aciera
Replied by Aciera on topic What is the "proper" zero origin
My theory is the front of the machine should be defined from where the operator stands. The x axis should run across your chest with the positive direction running left to right. The Y axis should run away from the operator with the positive direction running front to back.
+1
Zeroing a mill table at the front left is the same as zeroing a gantry at the rear right.
'Gantry' does not define whether it's the head or the table that moves.
I don't get pissed on forums, but every argument has 1 of 3 outcomes. 1) I prove you wrong and you say "oops", 2) you prove me wrong and I say "oops", or 3) somebody realizes they were wrong and says "well that's what I meant". The first 2 don't bother me either way, I'm not a fan of the 3rd.
Sometimes asking the right question is more difficult than giving the right answer.
[edit]
Thats the thing. I always refer to the movement of the tool in relation to the table for any machine, not the table movement on a milling machine.
And just to be clear about this: There is nothing to 'LOL' about this statement. This is actually the standard definition of motion direction when we talk about machine tools. Whether that is a knee mill, a gantry, a hexapod, a serial manipulator or what have you. If it wasn't then you would need different Gcode for all these machines.
Last edit: 12 Aug 2023 18:54 by Aciera.
The following user(s) said Thank You: tommylight, rodw, gitin
12 Aug 2023 14:42 #277733 by tommylight
Replied by tommylight on topic What is the "proper" zero origin
Oh yes it is! :)
12 Aug 2023 17:17 - 12 Aug 2023 17:18 #277743 by cmorley
Replied by cmorley on topic What is the "proper" zero origin
I think machine origin only really matters if you wish to use G28,G30 or G53.
And even then it's position is not that important as long as it's consistent.
g28/30 default to machine origin so having the origin somewhere safe might be nice.
If using a tool changer that requites a specific, consistent spot it might be nicer to G53 to X0y0z0 for tool changes rather then G53 x3 y1028 z1401
Chris
Last edit: 12 Aug 2023 17:18 by cmorley.
13 Aug 2023 02:03 - 13 Aug 2023 02:12 #277791 by blazini36
Replied by blazini36 on topic What is the "proper" zero origin
goodness this editor is buggy
Last edit: 13 Aug 2023 02:12 by blazini36. Reason: it's dead!
Time to create page: 0.196 seconds
