Linux CNC Newby basic questions...
- DarkPhoinix
- Thank you received: 6
13 Aug 2023 14:35 #277826
by DarkPhoinix
Linux CNC Newby basic questions... was created by DarkPhoinix
Hi all,
i want get in the trash mach3 and use linuxcnc next this questions:
1- linuxcnc work with usb port controller
2- why are chip powerfull usb controller to buy?
3- I see latency PC list, if i have last computer is best or why are special combinataion of hardware make best work with linuxcnc?
Thank you all.
Thank you all.
- Thank you received: 2163
13 Aug 2023 14:42 #277828
Replied by Aciera on topic Linux CNC Newby basic questions...
1. No
2. Not sure what you mean but probably not relevant since Linuxcnc does not work with USB controller
3. PC choice will depend on what interface you are planning to use (Parallel port or Ethernet connection to an FPGA board like the MESA products or EtherCAT )
- DarkPhoinix
13 Aug 2023 14:49 #277830
by DarkPhoinix
Replied by DarkPhoinix on topic Linux CNC Newby basic questions...
ok thanks,
1- I need a ethernet cnc controller?
2- Ethernet controller can cause problems compared to using a parallel controller?
13 Aug 2023 15:06 #277833
Use a parallel port with a simple breakout board (cheapest solution but somewhat restricted regarding step frequency and input/output options (eg no analog) )
Or use a compatible Ethernet board which is more capable and less demanding on the PC but also more expensive.
Note that, unlike with Mach3, LinuxCNC IS the controller so usually those 'ethernet controller' boards sold for use with MACH3 will NOT work with linuxcnc.
Time to create page: 0.167 seconds
