7i92t+7i77+7i70 sserial setup
19 Aug 2023 20:29 #278494 by Doug Crews
7i92t+7i77+7i70 sserial setup was created by Doug Crews
Hi everyone,I’m have not configured a sserial device before.  I’ve read the relevant sections of hostmot2 manual and I’ve seen several warnings from PCW through the years of posts to not flash cards with incorrect bit files. Could someone give me a go / no-go  on using the 7i92t_7i77_7i74.bin bit file that comes with the 7i92T support software download for a standard setup using 7i92t+7i77+7i70      The 7i70 is the ethernet input expansion board,  the 7i74 is also an Ethernet expansion board. Should be okay…?  The 7i70 is “self Configuring”  I just need to set the mode in the loadrt config modparam string.  I also need to remember to switch the jumpers on all boards to setup before flashing. Also, the 7i70 needs to be supplied field power from a power supply. There’s probably more but the bit file confirmation would set my mind at ease.thanks
-Doug
19 Aug 2023 21:15 #278499 by PCW
Replied by PCW on topic 7i92t+7i77+7i70 sserial setup
No flashing of sserial boards is needed (so no jumper changing either)
Time to create page: 0.177 seconds
